02-26-2015, 04:40 AM
1981 28' Airstream 280
Kitchener
, Ontario
Random shaking/ghost in the machine
Our '81 28' Excella has a strange way of getting our attention, she shakes and quivers like she is in a 6.5 earthquake.
Seriously for no apparent reason she starts shaking, from steering wheel to bathroom it starts fairly suddenly without warning and becomes quite violent. It usually happens at speeds over 45 mph and the only thing that seems to help is to steadily accelerate until it passes this takes some nerve but we learned very quickly last summer that slowing down makes it worse and that speeding up will help it pass. We can drive for hours without any issue and all of a sudden it happens and then will go away and not return or may happen again 10 min later. I've checked the driveline from front to back and cannot see any obvious problems.
Any advise would be greatly appreciated.
Chris
02-26-2015, 05:55 AM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
MOTORHOME problem
First two things that come to mind are: - brakes
- bearings
You might have something wrong with one bad brake. Immediately after it happens simply feel each hub and wheel. Any overheating on one indicates a problem that is there.... whether it's a loose or badly adjusted brake or a set of wheel bearings that is faulty or has too little grease requires tearing the thing apart to analyze, but either are easy fixes.
A tire out of round, or getting ready to fail due to tread separation could also be at fault.
But other than that, it's going to go back to the drive train, and that is where I admit total ignorance and find a great mechanic.
Paula
02-26-2015, 06:07 AM
1966 22' Safari
Hilltop Lakes
I agree with Paula, check all your running gear--bearings, brakes, bent wheel, bad tire, etc. Also include a good check of your steering mechanisms.
Consider it a safety issue until all that is done.
Drive line might have a bearing going bad or something. You need someone with much more experience in that area than I have. Back to Paula's suggestion of a great mechanic.
02-26-2015, 06:50 AM
z
, North Carolina
Well...
5 bucks says it's an imbalanced wheel.
You have more than likely lost a wheel weight. Most wheel weights these days use glue as opposed to the traditional ones that are "clamped" to the edge of your rim. In cold weather, that glue loses its "sticking" power, and can get thrown from the rim.
02-26-2015, 07:05 AM
1997 30' Excella
1954 22' Flying Cloud
San Antonio
It could also be the start of a belt separation or a bent wheel
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
02-26-2015, 07:38 AM
2000 31' Land Yacht
Central
While you have each wheel off checking the bearing, take them in to do a spin balance, last thing I would want is increased speed on a tire separation. While your weight is off the ground check the shocks.
02-26-2015, 09:06 AM
2015 30' Flying Cloud
Berrien Springs
, Michigan
Bent axle?
02-26-2015, 09:22 AM
Kitchener
, Ontario
Thanks for your input folks. The trick is it does not happen on a consistent or predictable basis. It will be fine and then go "shake and bake" for no rhyme or reason, if it was a predictable problem where every time I went over 50 mph it started it would be much easier to identify. I have not been able to locate or identify a bad tire or rim or brake thats what has me scratching my head. The problem is completely random as to when it happens.
02-26-2015, 02:11 PM
2013 30' Classic
Greenwood
, Mississippi
u-joints or drive shaft?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
02-26-2015, 02:27 PM
1989 34.5' Airstream 345
Ebro
, Fla Panhandle
A failing carrier bearing in the drive shaft gets my vote. The material surrounding the bearing within the carrier bracket failing can allow the shafts to get out of alignment Then sort of spring back into position the supporting material on mine is ribbed and you could some of the ribs distorting a bit..
Good luck sorting it out!
Cheers Richard
02-26-2015, 03:20 PM
1991 30' Airstream 30
San Francisco
How is your steering damper? I had a similar issue with my old Excella 28, really scared me. A new damper fixed the problem, and I would recommend replacing them with a new Bilstien in all cases if they are old or looking crappy.
02-26-2015, 04:13 PM
1999 30' Excella 1000
small town
, Maryland
As stated above, check the carrier bearing as well as u-joints. Replace if there's any play. I had the same problem on a 1970 GMC 3/4 p.u. it was the carrier bearing.
02-26-2015, 04:44 PM
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
Ever heard of the "Death Wobble "...Google it, common problem on Chrysler/Jeeps. My guess is the steering stabilizer is shot.
02-26-2015, 04:46 PM
north blenheim
, New York
P.S. A complete check of the other front end components is in order as well.
02-26-2015, 04:58 PM
Refugee from Napa, CA
2015 25' Flying Cloud
Formerly Napa
, On the road
axles????
Instagram. Alluminator
02-26-2015, 07:04 PM
1994 34' Excella
Warren
, Manitoba
I would replace the steering damper, or if the unit doesn't have one, I would install one. Way back in 1976 I bought a brand new Dodge Ramcharger4X4 fully loaded. After a month it developed a shake and I took it back to the dealer. In less than a year Chrysler bought the truck back. They tried new tires and rims, new axles,wheel bearings, hubs, U-joints, new drive shaft, new transfer case, new transmission, new motor mounts, and everything else possible. Nothing helped!! In 200 miles it would shake 2 or 3 wheel nuts loose. They finally admitted they had no idea. Good luck finding the problem, but try the simple first. Chris
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
02-27-2015, 06:11 AM
2000 30' Excella
2014 30' Classic
Princeton
, Iowa
I am sure this is right, will only add sometimes you get separation in the tire and it as to be replaced, first try balancing.
