Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 12-14-2007, 02:23 PM   #1
345bill's Avatar
Profile:  Las Vegas , Nevada
Question raising a 345mh
when i take my 345 in for new tires (8) should i be aware of any particular process to watch for concerning how they raise it? i've had wheels off previously but always one at a time and i doubt they will be that concerned. i'm mainly concerned with the tag and would rather prevent a problem than stand there and watch one happen. suggestions? thanks!
345bill is offline   Reply With Quote
Old 12-14-2007, 03:58 PM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
Front axle should be obvius, put a floor jack under each lower control arm, lift, change out the tires, and lower.
Rear axle is a bit more complex because of the tag axle. They may be able to raise the drive axle enough so the tag axle will also clear the ground.
(No Longer at Inland RV)
Old 12-31-2007, 10:32 AM   #3
345bill's Avatar
Terry- we used wedges in front & behind of the front wheels then used onboard levelers to raise the rear end & the tags did clear the ground. when all rear tires were changed we wedged the rear tires and raised front end with front levelers and all went well. decided to go with bridgestone, 8r19.5,m-724's. our to-do list got even shorter with the new tires as more than one "rattle" is gone. thanks for your input.
1000 mile maiden voyage in 345mh-we made it! s.s.sloan On The Road... 5 10-30-2007 11:05 AM
Raising the Flying Cloud dmaiden Axles 22 12-26-2006 04:15 PM
1986 345MH Exterior lights flash Classic Motorhomes 23 06-26-2006 12:21 PM
raising the trailer atvmcg Repairing/Replacing Floor &/or Frame 9 11-18-2005 09:10 AM
Raising Trailer Height John Sims Axles 2 06-24-2003 10:52 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
