Old 11-17-2016, 02:50 PM   #1
1992 35' Airstream 350
Saskatoon , Saskatchewan
radio antenna replacement
Newbie
How do I replace the radio antenna which is mounted on the drivers side of my 350 LE? Do you have to remove the inside panel to run the cable to the radio?
Silver Pit is offline   Reply With Quote
Old 11-17-2016, 05:06 PM   #2
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Yes...the driver's side panel has to be loosened, but not removed. All the rivets from the top rear of the sliding window along the curtain snaps to the floor need to be drilled out, then you will have access to where the antenna wire passes through the body. They used a lot of hard silicone when they installed it so you need to pry the old silicone out carefully from the inside. The original antenna is still available as u have replaced both of them in my 325LE and the 370LE. Do you have the factory rear radio and second antenna in the bedroom ? Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 11-17-2016, 05:08 PM   #3
bobmiller1's Avatar
I installed not u ....sorry..u is right next to i on my phone, Regards, Bob
Old 11-17-2016, 06:57 PM   #4
Yes I do have the factory installed radio in the bedroom but that aerial is ok. The front one is broken and I picked up a replacement at CanAm in Ontario. I think I will wait for warmer weather probably spring before tackling as it is around 30F here now and only going to get colder. Thanks for the info Bob.
Chimo Ted
Old 11-18-2016, 04:23 AM   #5
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Anyone have a part # for that front antenna, or a US source?
Cheers Richard
tevake is offline   Reply With Quote
Old 11-18-2016, 06:43 AM   #6
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Cheers Richard
Or a better one that would bolt up using the existing hole? (Or cover the existing hole)
mayco is offline   Reply With Quote
Old 11-18-2016, 09:57 AM   #7
The part # I have is #HS519L side mount antenna available from Airstream Supply Tel: 877 686 7331 or 801 972 2400. I believe is in Utah
Chimo Ted
Old 11-18-2016, 10:16 AM   #8
I bought a dual mount antenna off of ebay about 3 years ago and installed it on my Argosy. Sadly, within two years the antenna started rusting so it looks like I'm going to have to replace it again before I ever got to use it
ID:	275591Click image for larger version
Here's a couple of different choices I found on ebay.
Side Mount Dual Base ANTENNA
Dual Base Side Mount AM FM Antenna
Antenna Removal & Replacement with Cell/Wifi Antenna BoldAdventure Electronics & Connectivity 10 08-14-2017 07:24 AM
Radio Speakers but no Radio 1969 ???? tdoescher 1965-1969 Sovereign 13 04-21-2015 01:17 PM
cb radio, cassette radio jagcb750 Classic Motorhomes 14 04-19-2012 02:32 PM
Removal and replacement of outside radio antenna gryphon Electrical - Systems, Generators, Batteries & Solar 4 04-29-2005 12:55 AM
Correct speaker placement, radio antenna, etc. barbwire All Argosy Trailers 0 11-29-2002 06:28 PM
