Old 06-12-2012, 10:56 AM   #1
la nomade's Avatar
2018 22' Sport
stanfordville , New York
Radiator fan
as i was driving back from the garage where i had the Horn fixed,the back up light and the radio....close to home,a blessing,the HOT came on,on the dashboard and i realised the fan was not coming on...parked,and found the radiator cover dripping and a sizzeling,hissing sound.....i hope it did not damage anything...the collant now cold is way down,i know it was full when i left home...can it be the thermostat?bad electrical connection???where is the thermostat located???looked in A. stream manual,no mention of Radiator nor radiator fan....Help!!!!thanks.
la nomade is offline   Reply With Quote
Old 06-12-2012, 12:49 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
BUMP
"the coolant now cold is way down,i know it was full when i left home..".
Had you just filled it? Did you check it after running the engine? If the heater core was leaking, or a vapour lock in system, the rad may have appeared full, until running engine.
Have you got an electric fan? or a Viscoses oil type?
The thermostat, as such, would not normally run the fan, as there would be a sending unit for the electric fan. This sending unit would probably be on the engine block.
Dave
Old 06-12-2012, 01:56 PM   #3
t7389sg's Avatar
1991 35' Airstream 350
Laurel , Maryland
Bad Fan Clutch
If you did not hear the fan roaring when it got hot it would seem your fan clutch is not functioning. Itís easy to replace from the dog house. All it takes is a 1/2 inch wrench. I just replaced mine while at the Alumapalooza campsite. If you need a walk thru let me know because its all still fresh in my brain. Steve
t7389sg is offline   Reply With Quote
Old 06-12-2012, 02:21 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
First you have to determine where the coolant was coming out.
Was it the cap, in which case it was just re leaving the pressure from over heating. Over heating could be bad thermostat, clogged radiator, or bad fan clutch.
Was it cracked radiator or hose leak.In which case the coolant level dropped to a point the engine overheated and boiled the remaining coolant.
Don't replace anything till you determine why.
2004 Excursion 4x4
Old 06-12-2012, 02:32 PM   #5
la nomade's Avatar
2018 22' Sport
thanks Steve,i hope that is all it is,i would appreciate a walk thru...your air stream looks very much like mine!!!My friends by now call it Martine's great folly because i keep having to fix things,if its not one thing its another,and yet....the love affair goes on,with no reason or rime.....
Old 06-12-2012, 02:38 PM   #6
la nomade's Avatar
2018 22' Sport
Originally Posted by masseyfarm View Post
BUMP
Dave
quiet certain its a electric fan..will check for thermostat on engine bloc...thank you....will get my friend Don to come over to help me sort this out following all your suggestions...will keep you posted. M
Old 06-12-2012, 02:40 PM   #7
la nomade's Avatar
2018 22' Sport
Right....it was from the cap....will check it out thanks...love your mailbox!!!!
Old 06-12-2012, 05:49 PM   #8
t7389sg's Avatar
Laurel , Maryland
The fan you can see in the front of the radiator is usually the condenser fan for the ac. If you remove the dog house cover from inside the motorhome you can see the cooling fan behind the radiator. That fan is controlled by a fan clutch. When you first start the engine cold this fan should roar loud for a couple minutes and then calm down. It should get loud again when the engine gets hot while climbing a hill. The fan clutch seems to have a limited life on these big Moho. I too had the hot light come on in my rig so I am dealing with this too. It puked out its coolant into the overflow bottle and after filling that it all went on the ground. Check your overflow bottle and make sure there is a hose connected to the underside of the overflow bottle can to suck the coolant back into the radiator when it cools down. Mine was missing so the coolant only flowed one way. Steve
Old 06-12-2012, 07:08 PM   #9
1979 28' Airstream Excella 28
Commerce , Michigan
I went through all the same trial and tribbulations with engine cooling a few years ago. I recored the radiator to a 4 core and while i jad it out i put a flex fan in. Big mistake! The moho sounds like a convair 990 at take off and man do those fans take hp. My current project is going all eletric on the fans. Just a heads up as you sort this out.
DA TAZ is offline   Reply With Quote
Old 06-12-2012, 07:18 PM   #10
1982 28' Airstream 280
Redwood City , California
Love those pics...nice!
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 06-15-2012, 07:06 AM   #11
la nomade's Avatar
2018 22' Sport
it is the fan cluch
it is the fan clutch,i ordered a new one...should come in the next few days,your help in finding the problem is so great,thank you....what a difficult access ....but i have great help to fix this.....M.
Old 06-15-2012, 07:45 AM   #12
t7389sg's Avatar
Laurel , Maryland
A couple of tips when changing this fan clutch out. Put a piece of cardboard under the fan on the ground to catch any bolts or washers you may drop. I did mine in a field so I had to be extra careful not to drop anything lest it disappear forever. My coach is very close to your model so you should have room once you remove the clutch to just hang the fan on the water pump pulley and maneuver the clutch up and out from around the AC compressor. Other than that it’s just a yoga class being stretched out over the doghouse reaching for those bolts. Not too hard compared to other projects I've done on this thing. Steve
Old 06-20-2012, 07:01 AM   #13
la nomade's Avatar
2018 22' Sport
A couple of tips when changing this fan clutch out. Put a piece of cardboard under the fan on the ground to catch any bolts or washers you may drop. I did mine in a field so I had to be extra careful not to drop anything lest it disappear forever. My coach is very close to your model so you should have room once you remove the clutch to just hang the fan on the water pump pulley and maneuver the clutch up and out from around the AC compressor. Other than that itís just a yoga class being stretched out over the doghouse reaching for those bolts. Not too hard compared to other projects I've done on this thing. Steve
i am pleased to report that it is fixed,the new clutch went in,when tested,it did what it is supposed to do....all is well...thank you for your help with this,it made it all much easier....M.
Old 06-20-2012, 11:08 PM   #14
Glad you got it fixed. What manufacturer and part number was the replacement clutch fan? I'm not sure I'm happy with the second one I put on ;(
