Old 03-24-2012, 10:55 PM   #1
1982 28' Airstream 280
Redwood City , California
Radiator Advice
I'm having the shop that is doing some other work on my MH also pull the radiator and send it out to be recored.
I would like to see what others that have had this done recently, paid for labor and recore charges.
How many hours of labor did your shop charge you to remove and replace the radiator?
What did it cost for the recore?
Did they pull the radiator out from the bottom or through the front grill?
Do you have any other advice based on your experience?
Thanks for your help on this, I have to give the shop the go or no go on this on Monday or Tuesday.
Dean
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 03-24-2012, 11:04 PM   #2
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
The only thing I can add here is that for a vehicle of this age a re-core is a great option. Essentially the only parts reused are the tanks. As to time for the job? find an old flat rate manual for the vehicle and it will give you an indication of the time involved to replace the radiator for that chases when the vehicle was new. Most shops rightfully add time to the job for the age of the vehicle and certainly for any accessories that may be "in the way". You might be surprised at how much time is involved!
Bruce
Bruce B is offline   Reply With Quote
Old 03-25-2012, 07:20 AM   #3
1995 36' Classic 36
Ludington , Michigan
Get a quote from them and see if its something you can live with. I'm usually shocked and end up doing jobs like that myself. They packed a lot of stuff up there in those engine compartments. Its another nice thing about the pusher. I have an engine room with built in lighting instead of an engine compartment.
Kota is online now   Reply With Quote
New Air conditioner advice? marzboy Furnaces, Heaters, Fireplaces & Air Conditioning 92 07-26-2012 10:41 AM
Air Conditioner replacement advice NevaH Furnaces, Heaters, Fireplaces & Air Conditioning 16 05-10-2012 07:16 PM
Leak Repair Advice shankel128 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 03-24-2012 08:01 PM
Air Conditioner Hum, advice? Jim & Susan Furnaces, Heaters, Fireplaces & Air Conditioning 25 03-23-2012 01:42 PM
Negotiating Advice Needed on 2011 27' Flying Cloud Timberock Buyer Guidelines 13 03-16-2012 05:12 AM
