Old 07-07-2015, 07:10 AM   #15
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Aloha Mike, Good suggestion, I will check out the disconnect switches in the morning. I have been checking in and behind the battery drawer and doing some cleaning of ground points and connections there. What a mess of a layout that area is. The post about Mickey Mouse having done the wiring comes to mind. Quite a challenge tho having to allow for the travel of the drawer.
I really enjoyed our time hanging at Colorado Springs. Thanks for the tip, if it could only be that easy, I'll be stoked.
Cheers Richard
tevake is offline   Reply With Quote
Old 07-07-2015, 08:14 AM   #16
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
My "coach battery disconnect" on the 310 only disconnects the converter from the battery. I thought originally it was supposed to disconnect all the 12volt devices. After working on those switches yesterday I found that it just disconnects the converter from the battery. I guess to prevent over charging for the old single stage converters. ??????? Anyway, it's worth a look at those connections.
Lynn n I had a real good time getting to meet up with you and the others at the rally. So nice to put a face with the forum tags. You sound like you're off for more adventures in northern CA. Way cool. Your P looks awful good behind the 345.
Aloha,
Mike
mayco is offline   Reply With Quote
Old 07-07-2015, 09:44 AM   #17
1982 28' Airstream 280
Redwood City , California
Hi Richard, what is the material you used for the air dam? I like the clear clearance light in the compartment!
Originally Posted by tevake View Post
Oh I also made a new air dam for the front of the engine room while at it.
And repainted the colored part of grill and light buckets while I had them off the coach. That and sanding the bare metal parts down to 600 grit, really cleaned up the look of the front once reinstalled
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 07-07-2015, 10:24 AM   #18
I had to improvise a bit to get the stiffness in the material I was looking for the air dam.
I had a sheet of two ply rubber used for doing roof coatings on old fiberglass R Vs. Which was very playable . So I laminated a layer of that material on each side of a piece of the excess flooring material. A linoleum/ vinyl sort of more stiffer material . This resulted in a still somewhat flexible and heat, oil, chemi resistant material, that suited the job nicely.
If you look closely you can see the light colored flooring material showing where the cuts are.
If I had been able to find some thicker , less flexible. Rubber sheet material I would have used that.
Old 07-07-2015, 11:56 AM   #19
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
Battery isolators are always a roadblock to an efficient charging system for deep-cycle house batteries. Even the best quality diodes will create a voltage drop of about 750mV. Consider replacing the isolator with a battery "combiner" that senses charge voltage and connects the batteries using a relay. When the engine isn't running and the voltage drops below about 13.8V, the relay isolates the batteries.
Here's one from Victron:
Victron Energy CYR010120010 (R) Cyrix-ct 12/24V-120A Battery Combiner
And here's the Blue Sea Systems line of combiners:
https://www.bluesea.com/products/cat...harging_Relays
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 07-08-2015, 03:54 PM   #20
Thanks Gnorts, I hadn't heard of a battery combiner. Good info going forward into getting this charging stuff corrected.
I don't have deep cycle batts. Yet didn't want to splash out them till things are working properly
I've been in touch with Lewster in hood river and hope he can find time in his busy schedule to do some diagnostics work for me.
Towing capacity of 345 chopperbob General Motorhome Topics 11 09-06-2017 01:24 PM
Prepping an Argosy to be repainted RhinoWW All Argosy Trailers 3 07-18-2014 11:08 AM
Trips - Prepping the remotely sited Airstream IanPoulin Airstream Lifestyle 18 05-18-2014 05:16 AM
345 Motorhome :: 2011 Airstream 345 cowboy7877 Airstream Registry Discussions 0 12-27-2011 03:38 PM
Tips for prepping the floor for peel & stick MonaxLisa Floor Finishes 6 06-14-2010 07:53 PM
