I have replaced the power steering pump and high pressure hose as they were leaking (so I thought). I still have the leaks, so was wondering if there were any likely failure points before I start tearing the rest of the system apart. Thanks in advance!
Bill,
There are many.
On the pump itself, it could leak from the main shaft, and the reservoir to pump O ring, and the bolt on the rear right in this pic.
Then there are O rings where the pressure hose threads in. There are 2 low pressure hoses that return to the pump reservoir too, as well as the main feed pipe that comes in from the front mounted reservoir too.
