Old 10-13-2011, 04:06 PM   #1
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Power Seat Switches
Hi all,
Looked through the postings, and nothing came up, so here goes.
Moved my driver's seat all the way forward when I vacuumed and cleaned the carpets. Went to get into the Airstream today, and now the Drivers Seat switch refuses to move the seat back far enough for me to drive! Thinking I'm pulling the passenger seat switch, swapping it with Driver's seat switch until I get this figured out. Any suggestions? Any ideas?
Thanks, Derek
Old 10-13-2011, 04:54 PM   #2
1995 36' Classic 36
Ludington , Michigan
Might be as simple as needing lubrication. I pulled mine and lubbed everything. I hooked up a 12 volt battery and it worked like new. Reinstalled it and it would barely move just like before. Found a bad ground which seems to be a ommon cause for a lot of the electrical problems I've tracked down. If not, I think those switches are pretty commmon GM parts. The U-Pull-It junk yards can be a great source for $5 fixes. I restore old vehicles and admit to being certified dumpster dive master.
Kota is offline   Reply With Quote
Old 10-13-2011, 04:59 PM   #3
crazeevw's Avatar
Hi Dakota, seat moves fine forward, it's practically under steering wheel now, lol. Guessing that the switch to move it backwards either has faulty ground switch, or just needs replacing. I've seen these power seat controls in practically every GM car while growing up (friend was a Buick Dealer), so have a feeling I'm junkyard bound if the wiring isn't the cause. Thanks, Derek
Old 10-13-2011, 05:21 PM   #4
3 Dog Nite's Avatar
Cleveland , Tennessee
I went through this once. In a pinch, the seat was moved back out of the way by swapping the switches out from the other side. I only hooked up the wire connectors to move the seat. This also confirmed that my problem was the switch & not the wiring.
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 10-13-2011, 08:21 PM   #5
crazeevw's Avatar
Hi, I didn't have time to get to the switches this evening. I'm sure over the weekend I will though. Guessing that if by moving passenger side switch to drivers side, and all works, it's time to go to the local junk yard. Thanks, Derek
Power Loss & Pets Inside? Frank&Mike The Pet Forum 67 07-27-2013 08:57 AM
Solar Power for Battery Maintenance Tumajin Generators & Solar Power 10 08-12-2011 06:10 AM
Newbie has power questions Czechitout Electrical - Systems, Generators, Batteries & Solar 2 08-07-2011 04:20 PM
Stumped by power steering dadstoy Mechanics Corner - Engines, Transmission & More... 14 05-30-2011 01:57 AM
Power Steering Not Working - 310 Motorhome steveturk Classic Motorhomes 27 02-18-2011 05:00 PM
