Old 08-15-2011, 06:27 AM   #15
1989 34.5' Airstream 345
Silverton , Colorado
I have used a sharkbite connection behind the toilet in the moho, and one behind the washing machine in the home without wheels(splicing pex into copper)...our water pressure is at least 65 psi. m
(I swear I thought I already posted this...maybe it will show up on another thread)
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 08-15-2011, 06:47 AM   #16
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
Trust me space can be an issue at times, I would not have wanted to use sharkbite conn. in a situation like this: (there is a tool to remove crimp rings as well)
kevinb is offline   Reply With Quote
Old 08-16-2011, 09:56 AM   #17
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Hi Kevin,
I built a copper manifold in that very corner. What is the black thing in your picture? Is that the water pump?
ID:	137830   Click image for larger version
ID:	137832   Click image for larger version
ID:	137834   Click image for larger version
Phrunes is offline   Reply With Quote
Old 08-16-2011, 09:51 PM   #18
Bethany533's Avatar
1983 30' Airstream 300
Covington , Louisiana
Thanks for everyone's input. Another question: I'm not sure that the water heater is bad but thought while I have everything apart, it might be good to go ahead and replace the old unit with an up to date version. Any thoughts?
Bethany533 is offline   Reply With Quote
Old 08-17-2011, 12:17 AM   #19
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
My thoughts are...
If you currently have a 6gal and have room, go for a 10gal
Stick with Suburban
If you have a 10 gal currently and the tank is good, just update the valve with something with addl. Features such as electronic ignition etc. Any reseller can advise you on the options and their respective costs. Good luck.
'67 Safari plumbing diagram 2001sport 1966 - 1968 Safari 1 07-24-2011 09:08 AM
Back-up Lights - TV - issue Pinchy Lights - Interior & Exterior 3 05-10-2011 06:24 AM
Interior Plumbing Vent and cap the outside? robwok Roof 5 02-14-2011 12:27 PM
