Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 04-04-2011, 06:11 PM   #1
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Plastic Dash
I got no response in the Argosy forum so trying here. Has anybody repaired a cracked dash and if so what product did you use. I have tried epoxy and it won't bond to the plastic. The PO had used auto body filler and that did not work either.
Anybody know what type of plastic the early dashes were made from it is about 3/16 to 1/4 inch thick
Name:	Window leak repair 026.jpg
shepherd57 is offline   Reply With Quote
Old 04-04-2011, 06:39 PM   #2
steveturk's Avatar
1978 28' Argosy 28
Post Falls , Idaho
I ran across a website awile back that looked like a good repair method. I'm not sure of the web address but if you do a Google search " dash repair " it should come up. Look for " Dash Repair - Restoration Techniques by Daron Walker "
Good Luck !
steveturk is offline   Reply With Quote
Old 04-04-2011, 07:01 PM   #3
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 61
Dash Repair
Thanks for the good site.
Dave
Good Luck !
Old 04-04-2011, 07:25 PM   #4
Thats a weird dejavu moment Massey...
Thats an Alfa Romeo Dash, IIRC!
Shep, if that is a pic of the backside, that is expanded foam... and as such its just a filler..
If its the surface that has the crack..
Try rubbing the backside of the dash with MEK... if its softens then its ABS.
Old 04-04-2011, 09:24 PM   #5
shepherd57's Avatar
Lindsay , Ontario
Yes that is the backside of the dash it has some cracks where the defroster vents are you can see the blue body filler that the P O or somebody has put on. I read some place about MEK but I don't know if it is available here dose it have a product name or is MEK it.
How is it used
Old 04-04-2011, 10:08 PM   #6
MEK is the shortened name...
Kethyl ethyl ketone
Its a strong solvent like Acetone.
We can buy it at Home Depo here is California still, so it must be available there too.
Look here how I used it on an ABS part.
Post 90 , then 118 on..
http://www.airforums.com/forums/f311...e-62919-7.html
Old 04-04-2011, 10:41 PM   #7
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
I did a major rebuild of the dash in my 325 and used a two part WEST SYSTEM epoxy resin and fiberglass cloth from a marine supply store. Scuff the plastic with a very course grit sand paper to give the resin a surface to grab hold of. The cloth will bridge the gap where you now have a crack. The stuff is super strong and very stiff once it sets up.
As you may be working with the dash in an upside down position, be careful that the resin doesn't flow into places where you don't want it to go. It is very hard when cured, and difficult to sand by hand. You can use painter's tape or something similar to "seal" the crack in the area where you're working to control the flow of the resin. Good luck!
streamquest is offline   Reply With Quote
Dash Repair shepherd57 Argosy Motorhomes 2 06-22-2013 06:48 AM
Wheel well plastic jcessna Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 4 12-12-2011 08:56 PM
AS280 - Mystery Button on Dash dalefox Classic Motorhomes 42 03-15-2011 05:24 PM
Plastic Waste Tank Patch silversafari Waste Systems, Tanks & Totes 8 03-03-2011 06:53 PM
abs plastic seams cracked rayandre Sinks, Showers & Toilets 5 02-15-2011 03:56 AM
