09-16-2009, 12:22 PM
2006 28' Safari SE
Colorado Springs
P30 swaybar bushings for 81 Excella 280
The Chevy dealer in Tucson who is fixing our tranny output seal leak noticed that the sway bar bushings were dry rotted. I said go ahead and replace those but the problem is their parts guy can't locate a P30 chasis part number for them. My question is, did Airstream do something custom with the swaybars or is this a standard Chevy/GM P30 part? Also if anybody knows the part number please forward.
Ken
4CU Charter Member
09-16-2009, 01:06 PM
2008 27' Classic FB
1959 22' Flying Cloud
fairview
, New Mexico
Ken if its the sway bar frame bushing what counts is the diameter of the bar. Is the bushing the shape of a half moon? if it is it is the frame sway bar bushing. They are made for a 1 1/16, 1 1/8 ,1 1/4, and 1 5/16 dia bar. They are not hard to replace. In another life I was a Front End Mechanic. Anthony
09-16-2009, 02:17 PM
2008 27' Classic FB
fairview
, New Mexico
Check this out
Class A Motorhomes (listed by chassis type)
Chevrolet P30 / P32 / P3500 1968-99
Front sway bar 1-5/8" diameter
$225.00
Stage 1 susp. kit 1-5/8" diameter front bar kit w/poly bushing kit for stock rear bar
$265.00
Polyurethane bushing kit for front 1-1/4" stock bar
109-109
$62.95
Polyurethane bushing kit for rear 1-3/4" stock bar
$62.95
Front sway bar on Chevrolet P30 chassis - 109-151
Part Numbers Highlighted May be Purchased Online by Clicking on the Part Number
Dodge M400, M500 1973-81
129-100†
$340.00
Rear sway bar 1-5/8" diameter (with original equipment sway bar)
129-102†
$315.00
Rear sway bar 1-5/8" diameter (without original equipment sway bar)
129-105†*
$427.00
Dodge M600 1973-81
129-100
$340.00
Rear sway bar 1-5/8" diameter for vehicles originally equipped with a rear sway bar (modifications/welding may be required)
129-103*
$205.00
Rear sway bar 1-5/8"for vehicles without stock bar
129-104
$273.00
† Modifcation may be required.
* Welding required
Class A Motorhomes
09-16-2009, 02:22 PM
2006 28' Safari SE
Colorado Springs
Anthony,
You are the man! I will get this to our Chevy guy.
Ken
4CU Charter Member
09-16-2009, 03:09 PM
1984 31' Airstream310
Ajo
Ditto thanks! All p-30 mo/hos should have the front end aligned every once in a while.
09-16-2009, 03:18 PM
2008 27' Classic FB
fairview
, New Mexico
Ken here is a link to Moog suspention parts the parts are a lot cheaper. Moog makes a good suspension part. Had to stop and think of the brand that I used to get fron carquest. Chevrolet 2WD P30 Motor Home 1981 non 4 Wheel Disk Brakes, Moog Suspension Parts. They also have for4 weel disk brakes
09-16-2009, 03:24 PM
Ajo
I believe all AS mo/ho units have four-wheel disc brakes.
09-16-2009, 03:27 PM
2008 27' Classic FB
fairview
, New Mexico
On the moog sight it shows non 4wheel disk brakes and 4 wheel disk brakes for motor homes. not necessarily Airstream though
09-16-2009, 03:58 PM
2006 28' Safari SE
Colorado Springs
Mike,
I'm pretty sure our 81 280 only has disc brakes in the front. I think the rear duallys are drum brakes.
-Ken
4CU Charter Member
09-16-2009, 04:05 PM
Ajo
Interesting....we have full disc.
09-16-2009, 07:03 PM
2000 31' Land Yacht
Central
Originally Posted by arodriguez60
Was going to recommend Autozone until I went to this site, excellent prices.
09-16-2009, 07:04 PM
Ajo
Don't forget to have the mechanics lube the upper idler arms; most don't know they exist.
09-16-2009, 08:01 PM
Richmond
, Kentucky
Just FYI......
Argosy's for sure have rear drum brakes and possibly some of the early Classic's have rear drum as well. Our 84 310 has all disc brakes where our 74 20' Argosy has front disc and rear drum.
1975 24' Argosy Motor Home
