Old 09-08-2010, 05:42 PM   #1
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
P-30 front end question.
I'm wearing the front roadside inside tread big time. The other is fine, front end was aligned a couple of years ago. What should I be looking for after I get her off the ground? It's been suggested I might have a combination of the "bell cranks" and "radius steering arms" going south. What's a "bell crank", sounds spendy. Thanks in advance.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 09-08-2010, 06:58 PM   #2
Mike Leary's Avatar
Images: 11
Thanks anyway, made a appointment with Peterbuilt. They think it's the bell crank.
Old 09-08-2010, 09:15 PM   #3
Auretrvr's Avatar
Iowa City , Iowa
Supersteer was only source I could find for...
The issue for my '83 310 was the bell crank ARM (See URL below). I got two bell cranks and the bell crank arm from Henderson after looking for the arm unsuccessfully everywhere else I could. These parts changed the 310 into a very nice driver.
http://www.hendersonslineup.com/prod...-tracking.html
Airstream OCD...there is no cure!
1983 Classic 310 Motorhome.
AIR 15765
Auretrvr is offline   Reply With Quote
Old 09-09-2010, 02:58 AM   #4
1989 34.5' Airstream 345
Silverton , Colorado
Is "bell crank" as expensive as it sounds??? I would have aimed at air bags...m
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 09-09-2010, 08:19 AM   #5
Mike Leary's Avatar
Images: 11
Thanks, guys. Wow! Bell crank= PRICEY!
Old 09-14-2010, 10:09 AM   #6
I'm betting the price was somewhere around $330 each. At least that is what I paid about 3 years ago
Old 09-14-2010, 10:58 AM   #7
Mike Leary's Avatar
Images: 11
Was it a steering problem or tire wear that tipped you off, Brad?
Old 09-14-2010, 11:09 AM   #8
1988 32.5' Airstream 325
calgary , alberta
Hi to all! I just added new air shocks and the virtical steering shock from gm on my 1988 325 It made a remarkable differance! We have a lot of steep inclines and 2 lane roads here in base of rockies and just returned from 3-week trip Thought I was driving a limo. I'd try these first before replaceing expensive bell crank! Jonathan
jhenry is offline   Reply With Quote
Old 09-14-2010, 11:14 AM   #9
Steering problem. We couldn't keep the motorhome in our lane when a semi passed us We would literally get blown more than half way onto the shoulder. Turns out the bell cranks and drag link were bad on the drivers side, bad steering stabilizer and poor shocks all around. Replaced those components and steering got a lot better. Still need to replace the bell crank on the passenger side and I have a gut feeling the upper ball joints are bad.
Just haven't had time to get to those to fix them. To many other projects to deal with
Old 09-14-2010, 11:16 AM   #10
Jonathan,
Just FYI.
Its not hard to tell if the bell crank is bad. Just have someone turn the steering wheel from side to side while watching the bell crank. If there is any sloppiness it will definitely show.
Old 09-14-2010, 11:28 AM   #11
Mike Leary's Avatar
Images: 11
My steering is fine, but the wear on the roadside inside tread has got me concerned. We're going to jack the front this week before we leave and check it out. I had to replace the front tires, even though the curbside was even and had some miles left. Not interested in that $$$$ investment again before it's time!
Old 09-14-2010, 03:35 PM   #12
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
The toe-in on the left could be excessive. Also there may be too much negative camber, this would make the tire and wheel look tilted in at the top.
Either of these could cause the inside edge of the tire to wear.
Rob
Robfike is offline   Reply With Quote
Old 09-14-2010, 05:12 PM   #13
Mike Leary's Avatar
Images: 11
Thanks, well check everything else this week, but I have a hunch we need a alignment.
Old 09-14-2010, 06:11 PM   #14
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, check the ball joints; My P-30 "Mac Tools' truck came with an "I" beam front axle, But motorhomes and some other tool trucks had independent front suspension. I have seen a few on the side of the road, and a few others that were towed to repair shops with broken ball joints. That would not be a fun thing to have happen while driving at any speed. These are very large and heavy vehicles with this type front suspension and the ball joints were considered a weak point.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Front End Hitch centennialman Hitches, Couplers & Balls 14 01-13-2018 09:42 PM
Front End Murals Roadrunner Upholstery, Blinds, Walls & Interior Finishes 8 11-26-2009 06:39 PM
front end joboy1 Classic Motorhomes 3 05-27-2006 05:47 AM
front end alignment wb13798 Mechanics Corner - Engines, Transmission & More... 2 12-11-2003 12:11 PM
front end bottoms out!!? Curtis-79MH Airstream Motorhome Forums 18 09-15-2003 10:13 PM
