Old 01-07-2014, 10:02 PM   #1
arden_dean's Avatar
1986 34.5' Airstream 345
topeka , Kansas
Images: 26
overflow tank?
The overflow tank on my 86 345 cracked the plastic it's made of was to old and brittle to repair. So, do you think this one will work?
Aluminum Radiator Overflow Tank 4 or 6 Quarts New Made in USA | eBay
“The world is a book and those who do not travel read only one page.” – St. Augustine
arden_dean is offline   Reply With Quote
Old 01-08-2014, 07:18 AM   #2
SteveH's Avatar
Common Sense , Texas
I'm not a motorhome guy, and don't know if the one you link to will fit, but it seems sort of pricy to me.
I know you can get generic plastic overflow tanks for not very much money at most any auto parts store.
Regards,
Steve
Old 01-08-2014, 12:18 PM   #3
345bill's Avatar
Las Vegas , Nevada
[QUOTE=arden_dean;1400848] So, do you think this one will work?
Probably, but the plastic ones have the advantage of checking fluid level just by glancing at it. As Steve mentioned go to any good auto parts store and buy a universal one.
345bill is offline   Reply With Quote
Old 01-08-2014, 12:25 PM   #4
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
I want one, but I would miss my low coolant level sensors.
Waipio Rim is offline   Reply With Quote
Old 01-08-2014, 12:34 PM   #5
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
The aluminum one isn't going to crack.
Isn't the glass tube along the front the level gauge ?
Sergei
SmokelessJoe is offline   Reply With Quote
Old 01-08-2014, 10:32 PM   #6
arden_dean's Avatar
topeka , Kansas
Images: 26
Coolent level
The tube in front is plastic I was thinking of sizing it up about 1/2 inch or so then putting the level sensors in it.
None of the plastic tanks I found were large enough. The old one size is 10 x 8 x 5 = 400 in^3 = 7qt.
I was hoping for other options, it is a bit much.
Old 01-09-2014, 02:51 PM   #7
345bill's Avatar
Las Vegas , Nevada
arden dean- Here's a pic of the universal one I put in my 1990 345LE. Yes it has less capacity than original one but it has been in it now probably four years without any problems. I don't know if AS discontinued the tank sensors but I do know my 1990 has never had them, at least since I purchased it. Pretty sure this tank cost me about $15.
Name:	Photo0565 345 O'Flow Tank.jpg
Old 01-27-2014, 08:49 AM   #8
arden_dean's Avatar
topeka , Kansas
Images: 26
Talking spent the money
It was a bit much, but I'll never need to replace it. Call the guy and had him put a 1/2 inch set up for the level check. There should be no problems adding a senser block.
Thanks for your input.
Old 02-02-2014, 04:41 AM   #9
An aluminum tank is in my plan.
The level sensors rely on sensing the resistance across the 2 tank mounted sensors I think.
Covered with liquid = circuit complete, no warning lamp.
Uncovered = Circuit open, warning lamp.
They just need to be isolated from the tank body by mounting them in a grommet like the holding tank sensors.
Drill the correct size hole and deburr, insert the sensor, and tighten the first nut to expand the rubber seal, then attach your electrical connector between the first and second nut.
I like this style too...
http://www.ebay.com/itm/ALUMINUM-87-...555c27&vxp=mtr
Old 02-03-2014, 10:43 AM   #10
arden_dean's Avatar
topeka , Kansas
Images: 26
nice
it looks like that works too.
