Had an idea for an out door shower to just wash off sand and such. Would it be possible to use the city water connection and connect a hose with a shower head on it or is there some sort of check valve that won't let water flow out that connection? Also, what does "SOB" stand for? I know its the "other" camper/MH's but what are the words to it. Just curious. Thanks
"sqaure old box", i think
Absolutely you can. Get a pvc threaded connection for a waterhose at home depot. Connect the hose to that, then pvc to your showerhead.
SOB Square old Box,Some Other Brand,are you talking about tying onto the fresh hook up when you are disconnected from the hose and running on the pump,if so no water should come out.If connected to hose you can install a wye in hose and connect to hose.
Some people have installed hot & cold tees inthe trunk for a shower.Dave
Crashxx - you might want to read my post here. It will give you some ideas. Hmmm, that didn't work. I'll be back to try again.
Leigh (IB Aluminated)
"When a great ship is in harbour and moored, it is safe, there can be no doubt. But that is not what great ships are built for." by Clarissa Pinkola-Estes, author of ‘Women Who Run With the Wolves’
