Old 02-18-2011, 07:45 PM   #1
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
Optima AGM Red Top start Battery Install
Our Mechanic installed a new Red Top, 800 cranking AMP. I think ? and now I wonder if the GM Alternator will be able to correctly charge the AGM battery.
I know I read some Opinions of the Optima but I can not find the information now.
Thank You for your Input
John
John H. is offline   Reply With Quote
Old 02-18-2011, 07:50 PM   #2
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Hi John,
That battery is going to like to stay charged up and as long as the regulator is working correctly on your alternator and can supply up to 14.5 volts when all systems are running, lights, fans etc.. and maintain 13 volts under normal conditions you should be fine in my opinion.
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 02-18-2011, 07:57 PM   #3
Images: 13
Thank You Airslide
I have the coach back in the storage with the shore power charger on so I will see how she cranks tomorrow.
I also want to install a Mini Starter if anyone has a recommendation, and supply source.
I see Hitachi from 50. on E-bay to 300. at Jegs and Summit-racing
and Amazon.com
Old 02-18-2011, 08:29 PM   #4
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I have Optimas in all of my vehicles and have been very happy with them.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 02-18-2011, 09:44 PM   #5
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Yeah, me too. I aquired a bunch of used yellow caps 9 years ago & a pair have been working great in my Suburban, & 3 in my 59 Ambassador ever since. They haven't given me one bit of grief.
Colin
Colin H is offline   Reply With Quote
Old 03-18-2011, 08:00 PM   #6
Images: 13
I did find the issue.
A Loose Ground wire Bolt, Bolts. Both ends were Loose, the bolt into the Block on the engine. and the Nut on the Bolt on the frame.
Cured the , Hard to crank when Hot issue also.
as simple as that.
Just as a precaution. I also ran a ground from the starter mount bolt back to the battery ground on the frame.
Double Protection.
Old 03-18-2011, 08:18 PM   #7
moderator
Airslide's Avatar
Wilton , California
Images: 50
Good find. So often its a ground problem or connection rather than a component.
Vinnie
Old 03-19-2011, 11:24 AM   #8
Images: 13
some good battery maintenance aids available
QuickCable - Quick Compression
Old 03-19-2011, 09:17 PM   #9
The hard crank when hot is mostly a heatsoak on the starter issue.
Entry Door not tight at the top and bottom constructor Doors & Locks 9 02-28-2011 02:22 PM
Only one battery charging heslinhotel Batteries, Univolts, Converters & Inverters 11 02-21-2011 08:49 PM
Battery switch behind the sofa LawChick Batteries, Univolts, Converters & Inverters 9 01-13-2011 08:52 PM
