Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 08-19-2007, 09:22 PM   #1
jagcb750's Avatar
1986 30' Airstream 300
B , Louisiana
Onan NH-RV GenSet 6.5KW
I did a search on surging before I posted this and found several good threads on this issue. However, I couldn't find one exactly like mine so I thought I would start a new post about my particular issue.
When I started out in Ol' Nancy well just over a week ago, We started out in Texas. Whew, it was so hot. Nancy was a coach that had seemed to have been fairly well maintained up until maybe 3-4 yrs ago. I am the 3rd owner. The po before me had passed away due to illness and I believe he took regular care for her until he got sick. Anyway to the point.
The generator started right up when I first got her. It ran fairly well, but seemed like when you put a load on her she would start to surge. Nancy was at an RV dealership / service center. A technician there was fixing the blower on the dash a/c for the widow of the po of which I purchased her from. The tech told me that he thought the surging was due to a restriction in the fuel line or maybe the carberators needed cleaning.
We ran the generator all the way home to sweet old Barbourville, Kentucky which is about a 900 Mile haul. The generator didn't seem to surge too bad after she warmed up. There was a circuit breaker under the dining area that was turned off, so we only ran the one a/c plus the fridge. We stopped at campsites along the way and had shore power of which we didn't need to use the generator.
I turned on the breaker switch and had Nancy using both a/c units. Saturday when we decided to go camping I had both a/c units going and the fridge going. She didn't start surging until about 20 minutes later after we stopped at a place to wait to meet someone to return our great nephew back to his mom and dad. After the surging began we could not get the generator to run very long at all. After we got back home from camping today, I decided to see if I could get the generator to start and keep running. I disconnected from shore power at my house and turned off everything in the coach and tried to get the generator running. I changed the spark plugs the oil and oil filter. I could not get it to run hardly at all. The plugs were soaked with gas and the generator seemed to be flooding out. Not until I started messing around a little bit with the electric choke could I get it to run, but very rough. I gapped the plugs to .025 as suggested in the manual, the plugs were some knock off brand as well as the oil filter. I wonder if I am on the right track. I would take it to a certified Onan service center, but the Cummins dealership is 50 to 60 miles away. It will be a while before I can make that haul. I guess I may fiddle with it again tomorrow evening after it cools off a bit.. Again, any advice would be appreciated.
jagcb750 is offline   Reply With Quote
Old 08-19-2007, 10:22 PM   #2
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Tinker Toy
That sounds exactly the same way our Onan was acting.
Did all kind of fuel delivery tests.
Would not even run smooth on a shot of either.
Was getting worse every time I worked on it, very ego busting.
Ran out of time, as a road trip wasd approching, so had to spring for a new one.
Really want to here what you end up finding out, as mine was running wisper quite before bad gas problem showd up.
klattu is offline   Reply With Quote
Old 08-20-2007, 04:50 AM   #3
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
The older Onans surge for many reasons. I have one mounted on a wagon which was removed from my brothers RV and has only 60 hours on it. I set it up to use for Hurricane evacuation. I had to clean the carburetor due varnish from old fuel, lubricate and adjust the linkage. If you perform a Google search you will find several sites devoted to the Onan Generators, many were used it the GMC camper units. The best advice I can give is do some shopping on ebay and purchase the factory manual on disc and print it out. Get a good multimeter one that reads frequency, voltage, and temperature. Get a good stool and spend some quality time with you Onan generator the TLC will ensure that the ONAN loves you back. No reason why the unit won't do 10,000 thousand hours before Overhaul.
I don't think anything runs smooth on ether. I use it when I have to. On a Diesel I use WD40 the propane propellant give you a shot to turn the engine and the oil gives you lubricant. I learned that trick from an old Diesel Mechanic.
jagcb759, check your needle valve, it sounds as if your float is stuck due to vranish mine had glued it self to the bottom of the bowl and flood the engine I to could get it to run playing with the choke. Check your float level also. The electric choke is tricky did you mark the orginal postion ?
Check all your filters as a unit which has sat will pickup a lot of trash in the fuel line when put back into service due to the bottom of the tanks being stired up by road motion. Very bad on boats, the engine dies due to clogged filters as soon as the water gets rough.
When you get it smooth and adjusted, load it up heavy I use an old electric Kiln and check that it will hold the load for severeal hours. Don't use your ac or tv to load the unit find something which low voltage or high voltage won't damage.
Good Luck
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 08-21-2007, 09:15 AM   #4
jagcb750's Avatar
B , Louisiana
Here is an update:
I worked on it until 10:00pm last night. I took off the carbs and intake by removing the 4 bolts as suggested in the manual. the carbs looked clean. I took off the bowl and checked the floats and it looks emaculate. Everything was clean. I found some residue at the top of the carbs where there used to be a gasket that went in between the carbs and air breather tube. It looks like it had worn out. I need to replace it. The manual told me how to adjust the two set screws. 1 is for idle mixture and the other is for main gas level (throttle I guess). I found that the main one was loose. I sinched down the brass nut and woked the needle in to seat it so I could back it out the recommended amount. But I noticed that the needle looked out of round. So I backed it all the way out and I found some of that black sticky gasket material like that was above the carbs. I am assuming that that gummy gasket may have been sucked in through the carbs and got stuck on the needle where the spring tension is at. So I cleaned it off and sinched down the brass nut and screwed in the needle. The needle didn't look out of round anymore. Backed it out the recommended amount and put her back together. It purred like a kitten. However, when I put a load on it it would start surging. The GenSet did seem to run very quietly. I think I need to set it up a little. It was showing 120 Volts in the coach at a recepticle above the sink. The lights seemed a little dim. The refrigerator worked fine, but when I turned on the front a/c, the surging began. The manual has a section in it that tells me how to adjust the carbs. Then it seems like it suggests working on the governer.
Old 08-21-2007, 08:02 PM   #5
jagcb750's Avatar
B , Louisiana
well, it looks like I spoke too soon. I went to start up Nancy's GenSet today and it was back the way it was before. Flooding like crazy. could not even get it to start back up. Looks like it has beaten me. I will have to seek the help of a pro. I guess I will have to make the haul over to a cummins dealer to get it serviced.
Old 08-22-2007, 01:42 PM   #6
jagcb750's Avatar
B , Louisiana
I just got to give it one more go. I am going to tear into it one more time. I will remove the carbs again and this time I am going to completely dissassemble the float / needle valve assembly and inspect the needle valve. I still believe that the problem lies in this area. Everything I have read leads me to believe that there is just too much gas in the float bowl. I will inspect to see if there is some kind of vent tube that may be stopped up. I worked on an atv a couple years back and a dirt-dabber made a nest in a vent tube and it took me forever to figure out that it was the problem. I adjusted like crazy on the float and done everything, but there was so much gas that it was backing up into the air box. This is a similar scenario, but I don't know if the two carberators are made similarly in that respect.
I will post back with my results. Genset = 2 / JaG = 0........
Old 08-22-2007, 03:51 PM   #7
richinny's Avatar
2011 34' Classic
don't forget to see if the floats are porous. you'll notice that when dry they become much lighter. redip in fuel after drying and see if they feel heavier.
Ricky
Old 08-22-2007, 08:06 PM   #8
jagcb750's Avatar
B , Louisiana
@richinny: my floats are made out of tin like metal.
update: I cleaned the whole carb with carberator cleaner. backed out the main adjust screw and cleaned it. the seat looked good. backed out the idle mixture screw and cleaned it and the seat looked good. took the needle valve out and cleaned it and the seat looked good. sprayed carb cleaner with the little red hose in all the holes I could find. Did not find any vent tubes. put her back together and again it purred like a kitten. this time after 10 minutes of smooth running I started adjusting the carbs as suggested by the operators manual. It seemed that the genset was running great even after I put a full load on her. It wouldn't allow me to set the governor down to 100volts on the low end though. I couldn't get any lower than about 118 volts. I then as one of the last steps was to adjust the main fuel adjustment but could not get the voltage to drop until I almost seated it all the way in. So I ended up getting it all out of whack again i think. Still it didn't start surging until I turned one of the a/c units off. It stayed surging until I held back on the governor a little and tried to smooth it out. I will try again tomorrow.
Old 08-22-2007, 09:30 PM   #9
Liberator
klattu's Avatar
1972 Argosy 24
Images: 834
Onan the Carbarian
At least you know where the problem is...the carb.
Found some new ones on Ebay for $150 +/- based on model.
Think I will try that when I get back to Onan
Old 08-23-2007, 02:44 PM   #10
jagcb750's Avatar
B , Louisiana
@klattu: I hate to hear you are having these problems too, It sure has been nerve-racking on me. I wish you luck with yours and let us know how it turns out for you.
Here is an update:
I tore into that sucker again. This time I took the needle valve and float out. The float is made out of a material that is like tin. I bought some carb cleaner and cleaned everything. I sprayed it in every orfice I could find. I backed out the main fuel needle and sprayed it down. I backed out the idling mixture needle and sprayed it down and put it all back together. I started it up and it purred like a kitten again. then I got the manual out and started tinkering with the governor assembly. After messing with the tension a bit by how the manual stated, I was able to apply a big load on her. 2 a/c units and the fridge. She took the load quite well. I let her run for a while. After I tried turning off 1 of the a/c units. She started to surge again. Then I ran and shut down the 2nd a/c unit so it wouldn't be damaged from the surging. and it kept surging. I could run out the the Genset and pull back a little on the governor and the surging would subside. I think I am getting close. If I can't adjust it out, the book states to change the spring on the governor, because it may have gotten weak.
Old 08-23-2007, 02:47 PM   #11
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
An Onan tech told me that surging is usually caused by the governor spring weakening. You might try replacing the spring. Mine is running fine now.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 08-23-2007, 02:52 PM   #12
jagcb750's Avatar
B , Louisiana
@Cooperhawk: Wow we must have posted at the same time. With the same answer.
Old 08-23-2007, 02:54 PM   #13
The Hawk's Lair
cooperhawk's Avatar
Wink
Just goes to show that great minds think alike.
AKA THE GUNNER
VFW, LEGION, NRA
Old 08-23-2007, 03:51 PM   #14
1987 34' Limited
1987 34.5' Airstream 345
Tyler , Texas
Onan 6.5
HI! I to had the surge problem and took mine to an authorized Onan repair shop here in East Texas. They kept the MH for 7 months before they said it was repaired...said that the choke was the problem. Took the rig to the crawfish festivel and Onan ran for about 6 hrs and started surging again..Thru my hands up and bought another unit off of e-bay. Other Onan is back at the repair shop for about 4 months this time...hope your luck beats mine!
Pete
pjude is offline   Reply With Quote
Old 08-23-2007, 09:46 PM   #15
Liberator
klattu's Avatar
1972 Argosy 24
Images: 834
Oswaldo
I ran out of tinkering time for the Onan, had to by a new one.
Kept the old one for playing with later.
Too much depended on it running dependably.
I thought that grassy knoll in you avitar looked familar !
Was looking real hard at your MH last October.
Could not agree on a price with them.
Only one I have seen with those dark guards on rear.
Was it as clean as they said?
What type of roof AC are those?
They work good in this heat ?
Old 08-24-2007, 05:27 AM   #16
richinny's Avatar
2011 34' Classic
floats
metal ones can leak too, easier to check as you just have to shake them.
as for the choke, it should be wide open when warm. sometimes carbs need to soak in a carb bath to open up the tiny passages inside. you might try to find a rebuilder that has experience with thse carbs or go new. carbs can be very fustrating (been down that road myself). i hope that spring replacement works out for you.
Ricky
Old 08-24-2007, 09:21 AM   #17
jagcb750's Avatar
B , Louisiana
@klattu: hey, you found nancy. It was pretty clean. all original from what I can tell. The hose that feeds the water supply was eat up. the elbow in the back left rear corner that feeds the water supply leaked and had to be replace with a high pressure fitting. The Generator is surging. The 30 amp plug-in had to be replaced. It was shorting together and was getting very hot. The Master cylinder was empty in one chamber and half full in the other. the engine is dieseling on occasion. The roof a/c's are colemans. one of them does not have adequate intake in one side (the front one). I need to take a saw zaw and cut The panel out on the roof on one side. they would work good if I can get the generator running correctly and do a mod in the generator compartment to feed the rear a/c separately with shore power. Oh, the front a/c is weaker than the rear. I believe that I may be able to fix it by letting the door side get a little air in the intake side as stated above.
@richinny: thanks, I hope I can adjust it out. If not I will probably bow down and seek professional help. Thanks to all. I hope to get this problem resolved this weekend If I can get a new spring by then.
Old 08-24-2007, 10:55 AM   #18
Liberator
klattu's Avatar
1972 Argosy 24
Images: 834
Sounds like your working on mine...same problems
Carbs on Ebay
eBay Motors: GENUINE ONAN CARBURETOR #146-0802 (item 2482505412 end time Sep-01-07 04:17:45 PDT)
Old 08-24-2007, 07:26 PM   #19
jagcb750's Avatar
B , Louisiana
@richinny and jim clark: I think you guys are still on the right track.
Let me give everyone another update:
I didn't tear into them this time. After adjusting around on it for a while and figuring out that no matter what I did it was running really rough, I decided to unplug the fuel pump. Straightened right out. It cleared up in just about 5-10 seconds and ran smoothly until it ran out of fuel. Then I plugged it back in and it ran smooth for a while then would load up with fuel and I would unplug the fuel pump and it would straighten back out. One time it ran smooth enough for me to adjust the governor and put a load on it while I was doing it. It started surging again and I would pull the fuel filter plug and it would straighten out again.
It sounds like the needle valve is bad, or the seating surface where the needle valve is wore out, or the floats aren't floating anymore or the fuel pump is too powerful or creating some kind of added pressure. Anybody feel free to chime in here. I wish there was an Onan dealer in town. Anybody know of one online that accepts credit card?
Old 08-24-2007, 07:47 PM   #20
It sure sounds to me like the fuel pump is over coming the float/needle valve causing the motor to flood from excess fuel. After you shut the pump off the bowl starts emptying and you're running good for a brief period. I'd say replace the float and needle valve and you just might have your problem licked.
Good luck!
1975 24' Argosy Motor Home
Replacing Onan for a portable generator Paul Daugherty Airstream Motorhome Forums 7 06-15-2012 08:43 AM
Switch out Onan 4.0BF genset? abridges01 General Motorhome Topics 8 09-26-2006 07:28 AM
Onan GenSet starter problem JBK Generators & Solar Power 0 06-03-2006 02:12 PM
Onan Genset not starting Nick Danger Mechanics Corner - Engines, Transmission & More... 8 04-15-2006 07:40 PM
Generator onan Paul Daugherty Airstream Motorhome Forums 6 11-26-2002 12:51 PM
