Old 12-12-2008, 05:16 PM   #1
345bill's Avatar
Las Vegas , Nevada
Question Onan just quit
This concerns our 1990 345LE MH with Onan 6.5 NHE Emerald 3.
After it quit running here's what I've checked in order:
1. Both fuses at gen-set, OK
2. Engine turns over fine.
3. Good spark.
4. Removed air cleaner and gave quick shot of start fluid. It then started right up but only for an instant.
5. Removed fuel inlet line at carb, cranked eng. and no fuel. (DRY)
6. Removed supply hose at fuel pump and was wet.
7. Unplugged fuel pump 12V. connector at pump and found no feed to pump.
I dont know where this 12V. feed wire originates. DOES ANYONE ELSE KNOW where I should check next before I start taking things apart ??
Any other fuses involved ?
I would guess that it would involve direct to battery 12V. somewhere, I just dont know where. Considering the vehicle ignition switch position doesn't affect the Onan squashes my knowledge of electric fuel pump on this one. Thanks...
345bill is offline   Reply With Quote
Old 12-12-2008, 07:07 PM   #2
3. Good spark.
You maybe looking for a problem that you don't have.
All generators have a separate fuel line coming from the fuel tank.
That "dip tube" does not go to the bottom of the tank, but only about 3/4 of the way, by design.
Therefore if the fuel tank is not full enough or if the coach is parked on an angle, then you just cannot feed any fuel to the system.
Add 20 or 30 gallons of fuel to the tank, and I believe the problem will go away.
The design is such that if your running the GEN, you cannot deplete the entire fuel supply.
Old 12-13-2008, 09:59 AM   #3
345bill's Avatar
Las Vegas , Nevada
Andy-
The Onan has previously run out of fuel when the MH guage shows a little than 1/2 tank. I didn't mention the fuel tank is presently full.
Am I correct in thinking the Onan's electric fuel pump must have constant 12V. feed ?
The red wire coming out of pump has a male push in connector and the female connector that it plugs into does not have any voltage.
Isn't this the 12V. supply wire ? Or am I missing something ? Thanks
Old 12-13-2008, 10:13 AM   #4
Andy-
I don't have any schematics at home.
The fuel pump must operate to provide fuel for the generator.
Old 12-13-2008, 11:31 AM   #5
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
When was the last time the fuel and air filter was replaced?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 12-13-2008, 01:55 PM   #6
345bill's Avatar
Las Vegas , Nevada
Mike- The in-line filter and air filter are less than 1 yr. old. I just sent you a message on Dick's water pump thread before I read this one from you. Thanks
Old 12-13-2008, 02:23 PM   #7
Mike Leary's Avatar
Images: 11
Hope this helps; spark plug? My guys have told me the solid-state ignition in
the later Onan units is junk. That linkage could be the problem. So could be the battery cable running back to the gen set be trashed and not putting out enough to fire it.
Old 12-13-2008, 03:10 PM   #8
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
There is also a low oil cut off. Check the oil level of the genset.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 12-13-2008, 03:13 PM   #9
The Hawk's Lair
cooperhawk's Avatar
I have the manuals for a 1985 model scanned. If you need them I can e-mail them to you.
AKA THE GUNNER
VFW, LEGION, NRA
Old 12-13-2008, 03:36 PM   #10
Mike Leary's Avatar
Images: 11
Hope all you guys have these hr. meters.
Old 12-13-2008, 04:13 PM   #11
345bill's Avatar
Las Vegas , Nevada
Mike- You're right on when you asked if I can hear it powering up.
That clicking sound that all electric fuel pumps make is not present. That is why I checked for 12V. and found 0 at the pump.
Shows good spark at plug and will run momentarily if I manually prime carb. Thanks
Old 12-13-2008, 04:41 PM   #12
345bill's Avatar
Las Vegas , Nevada
Gunner- Oil level is OK. Now that you mention it seems I remember reading elsewhere on thse forums someone else had similar problem and it turned out to be faulty low oil sw. I will search for that post.
Appreciate the e-mail offer but I think I have the manual around home somewhere, if I can remember where I put it. I'll let you know. Thanks
Old 12-13-2008, 07:38 PM   #13
Bill,
I might be wrong but I thought the power for the electric fuel pump came from the same place power to the coil comes from.
Just a thought.
Old 12-13-2008, 09:23 PM   #14
345bill's Avatar
Las Vegas , Nevada
Originally Posted by bkahler View Post
Bill,
Just a thought.
Brad-
And a excellent thought that is. Seeing that it will run momentarily if I manually prime carb, a temporary jumper from coil to fuel pump pos. wire sounds like my next logical step. Thanks
I quit Smoking RichardT Off Topic Forum 404 01-27-2015 09:54 PM
We Quit ericinrb 2005 and newer - Bambi all models 99 07-18-2009 11:16 PM
'96 LY fridge quit working airstream96 Land Yacht/Legacy Motorhomes 5 07-02-2007 09:05 PM
Water Heater Quit again carnegie1935 Water Heaters, Filters & Pumps 5 03-20-2007 06:56 PM
**Chris Quit Blinking At Me** Silvertwinky Our Community 6 09-02-2003 11:11 AM
