Old 12-13-2008, 10:19 PM   #15
Originally Posted by 345bill View Post
Brad-
And a excellent thought that is. Seeing that it will run momentarily if I manually prime carb, a temporary jumper from coil to fuel pump pos. wire sounds like my next logical step. Thanks
On vehicles with electric fuel pumps I think the power feed also goes through an oil pressure switch. If there is low oil pressure while the engine is running the fuel pump shuts off. During starting this switch is bypassed to allow the engine to start. I'm wondering if your generator might be set up the same way and something is wrong with the start bypass switch or its contacts.
Bottom line is you should be able to run a +12 vdc hot wire to your fuel pump to see if it runs. If it does then you just have to back track the wiring to the pump itself.
Good luck!
Old 12-19-2008, 05:47 PM   #16
345bill's Avatar
Las Vegas , Nevada
ONAN UPDATE:
I think it was a combination of problems. Running a jumper wire direct to fuel pump pos. did make the pump start "clicking", however it still would not pump fuel, even when I put the fuel inlet hose into a full gas can. So I went to Onan parts house and bought a pump, oil pressure sw., oil and filter.
Came home and it snowed all day so I impatiently waited until today.
Anyway it is dry out today so I installed all above parts plus 4' of fuel hose and new in-line filter.
Had a smile from ear to ear when it fired right up and just purrres.
So THANKS to EVERYONE for your input, now back to the list of other items needing attention.
345bill is offline   Reply With Quote
Old 12-20-2008, 06:59 AM   #17
Bill,
Happy to hear you got it going again. Sounds like it was probably the pressure switch causing you the most grief.
I quit Smoking RichardT Off Topic Forum 404 01-27-2015 09:54 PM
We Quit ericinrb 2005 and newer - Bambi all models 99 07-18-2009 11:16 PM
'96 LY fridge quit working airstream96 Land Yacht/Legacy Motorhomes 5 07-02-2007 09:05 PM
Water Heater Quit again carnegie1935 Water Heaters, Filters & Pumps 5 03-20-2007 06:56 PM
**Chris Quit Blinking At Me** Silvertwinky Our Community 6 09-02-2003 11:11 AM
