Old 08-29-2012, 05:46 PM   #1
Fairbanks , Alaska
On the Road -- Please Help!?
Hi everyone, well am up here in Alaska and getting some minor work done.
Turns out we discovered major cracks in the fuel tank and I need a replacement tank.
My moho is a 1989 P30 chassis airstream 345LE with an 80 gallon tank.
We can't seem to find the proper replacement part anywhere online or off.
Anyone know what the ref. number/part number it is? and where I can get it??
The only one we have found are 40 gallons.
Any help is appreciated -- because I have to hit the road back to the lower 48 SOON!!!
Chris
Liz and Chris -- Follow our Full Time Adventures on http://www.gypsymoments.com
Visit my new Airstream renovation blog here:
http://www.AirstreamLoft.com
gypsychris is offline   Reply With Quote
Old 08-29-2012, 05:55 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Come on California Groupe... Vinnie get your allies out and help.
Old 08-29-2012, 05:55 PM   #3
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Hi Chris,
Anyway possible to 'seal' the tank with a gas-tank sealer, or are the cracks much too large? Have you tried searching the forum? I'll see what I can find, and will post any links if I find anything.
Good Luck, Derek
Old 08-29-2012, 06:06 PM   #4
Fairbanks , Alaska
No luck really so far I have searched the forums all day. The cracks are all along the brackets that hold the tank and are pretty sever. The rust is pretty darn deep (This was a North East moho -- which would explain all this.
HELP PS> I dont want to be stuck here!!! LOL Winter in Fairbanks is fast approaching and my home can't move!! LOL
Old 08-29-2012, 06:23 PM   #5
Fairbanks , Alaska
Anyone?
Old 08-29-2012, 06:27 PM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, radiator shops are well known for repairing fuel tanks. If nothing else, put a junk yard tank in it just to get you back home. They say Alaska has everything, but when I was there last year I found that to only be partially true. [we have motor oil, but not the brand a weight that you want] .....[we have tires that size, but not the same as you have on your vehicle] ... My Lincoln uses Premium fuel, but many gas stations only had two choices, Diesel and Regular 87] And I was yelled at because I asked if I could get my oil changed on Saturday. "WE DON"T WORK ON SATURDAY!"
We still had a wonderful trip to Alaska.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-29-2012, 06:33 PM   #7
Fairbanks , Alaska
Update -- One of the mechanics here says he can weld it -- so that is what they are going to do, Yoohoo.
Would still like to know what that Tank part number is etc. so I can track one down...
Old 08-29-2012, 08:23 PM   #8
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Send Brad aka bkahler a message, maybe he can get you the tank out of the 345 he is parting out.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 08-29-2012, 08:28 PM   #9
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Excellent advice.
Remember when Alumatube (Susan) and I met you guys at the North Little Rock KOA a couple of years ago in their 310? We kept saying that it was too bad that Brad was out of town and couldn't come. Same Brad. One of the good guys.
On edit, OK it was four years ago, not just a couple. Geez.
Vaughan
Old 08-29-2012, 09:08 PM   #10
crazeevw's Avatar
Chris,
PM AirRowan, he had a good write-up on how to remove the fuel tank I believe. You'd think it was a simple drop.....at least I believe it was AirRowan. Try and call Airstream tomorrow, as well as Andy at Inland RV to see if either can get you a part number.
Good Luck, Derek
Old 08-30-2012, 05:18 AM   #11
Chris,
The fuel tank is still available from the 1986 345. I haven't removed it yet and hadn't planned on removing it for a month or so however, if push comes to shove I would certainly do what I could to get it removed sooner.
Something you should keep in the back of your mind, if your tank has cracks in it that to me indicates its been stressed pretty good. I'm guessing the roads in Alaska aren't quite up to the standards of the lower 48 (which really aren't that great either ). The metal is fatigued so bottom line is don't be surprised if more cracks show up on your trip south.
Anyway, I'll help in any way I can.
Good luck!
Old 08-30-2012, 05:40 AM   #12
Member Slide Out Society
2004 28' Safari S/O
Zavalla , Texas Airstream Harbor
I have used MarineTex many times on fuel tank repairs for old cars that I rebuilt. You might look around at an auto parts store or a marine repair shop for that in Alaska or have it shipped to you from someone here in the lower 48. It's about the best I've ever found. Even repaired my son's electronic fuel pump on his Fiat with it...never leaked...hope this helps as an option..
Rockwell
Rockwell is offline   Reply With Quote
Old 08-30-2012, 06:23 AM   #13
Airstream Driver
1997 30' Excella
Images: 51
I pulled the 80 gal fuel tank before on an Airstream Moho and it is surprisingly easy, if the tank is completely empty. I just used a regular floorjack on wheels and a combo of the right size piece of plywood/2x4's after i figured the heights of the chassis to pull it out the back.
Great time to replace the rubber line!!
1996 Airstream B190
AIR #13
