Old 09-11-2012, 08:02 PM   #43
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
What a little heat will do to a turbo:
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 09-11-2012, 08:26 PM   #44
Mike Leary's Avatar
Images: 11
Here's what a fresh turbo looks like: Seems like a whole new design.
Old 09-13-2012, 07:02 PM   #45
Mike Leary's Avatar
Images: 11
Good news, new turbo back in, ran her to operating temp, no noise, no pistons sticking out the side. Bad news for the rest of you with turbo-powered coaches: The Garrett # 409080-9012 is our turbo, and the number matches the one we just got. The problem(s) are there was no flange for the oil feed (center of pic #1) and my mechanic had to machine one. The other problem was the housing on the right hand side was backwards and had to come apart and be rotated to align to the Isuzu. Odd that our second turbo bolted right on, but this one (made in Mexico) is a bearcat to re-align. My mechanic is not pleased with the lack of service from Oregon Fuel Injection, Inc., as they never returned his calls about the flange.
ID:	168222   Click image for larger version
Old 09-13-2012, 07:13 PM   #46
1981 31' Excella II
New Market , Alabama
You could have rebuilt the old turbo with new bearings. Your old turbine looked perfect.
I am glad it is running ok.
Perry
Old 09-13-2012, 07:13 PM   #47
Central , Mississippi
Have you considered doing oil analysis checks over the next few days/miles? I have a pal with a monster C class Ford/6.0L and he uses that method to make sure it's not preppin to 'let go'...pretty cool what they can tell from a few drops of oil, they could probably alert him that his wife is expecting...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 09-14-2012, 08:02 AM   #48
1981 31' Excella II
Yeah I agree there. Blackstone labs is a good place to send oil. You can tell them what happened and they can look for wear metals and tell you how bad your engine was damaged.
Perry
Old 09-14-2012, 09:00 AM   #49
Mike Leary's Avatar
Images: 11
Perry
We had talked about that very thing. The question is whether Garrett will sell us parts. Coach is heading out for tires right now, cross your fingers!
Old 09-14-2012, 09:20 AM   #50
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
My experience, back in the 1980s though, is that parts are very difficult to obtain.
I worked in a shop that rebuilt engines to pump water for center-pivot irrigation systems in the NW corner of the Texas panhandle. One winter while business was slow, we decided that I would dig the best cores from our 55 gallon barrel of turbo trade-ins and rebuild them.
I ended up rebuilding about 15 turbos that winter, but getting the parts took a long time and was extremely difficult, and we were a significantly sized shop. I doubt that it has gotten any easier since then.
Best of luck with your engine. Hopefully all will be well!
Vaughan
Old 09-14-2012, 10:22 AM   #51
Mike Leary's Avatar
Images: 11
Made it to the tire store, Bess seems to running fine, good oil pressure, boost where it needs to be; might have dodged a bullet here. Will run back to the mechanic's and check everything out, take a deep breath, and tomorrow head for Arizona.
Old 09-14-2012, 10:28 AM   #52
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Sounds good.
Have a safe trip.
DAve
Old 09-14-2012, 02:41 PM   #53
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Glad to hear that things are looking good. I've had my fingers crossed for you.
I'm sure there's no need for advice since you'll probably be staring at the gauges most of the time and listening for a pin to drop, but I'd keep an eye on the water temperature since that might be where you'd see the first signs of anything funny (or not so funny) starting to happen.
Good luck!!!
streamquest is offline   Reply With Quote
Old 09-14-2012, 05:04 PM   #54
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I certainly hope that the turbo is all that was needed and and your trips can continue.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-14-2012, 06:10 PM   #55
Gypsy Jo's Avatar
1977 28' Argosy 28
Bullhead City , Arizona
Glad everything is working out on the engine.
Hope your trip to Arizona goes well. Still in the 90's but can feel fall in the air here .
Jo
Gypsy Jo
1977 Argosy 28' Motor Home
Gypsy Jo is offline   Reply With Quote
Old 09-14-2012, 06:20 PM   #56
Mike Leary's Avatar
Images: 11
Thanks, all of you, for your support and input. I do believe someone was smiling somewhere. My tire guy said my 19,5s are the largest he can spin balance.
ID:	168299   Click image for larger version
