Old 09-20-2006, 11:51 AM   #1
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
oil sending unit for 85 MoHo?
looking for a part number or source for the oil sending unit on an 85 454 345 motorhome any ideas our mechanic thinks it will be hard to find thanks
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 09-20-2006, 03:17 PM   #2
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
It only has to match the input (ohm) of the gauge, and of course the threads on engine.
Does not have to be an original GM or AS part.
First try AutoZone/Advance, if no luck with them go to NAPA.
They should figure out a match.
klattu is offline   Reply With Quote
Old 09-20-2006, 04:40 PM   #3
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Ron and Debbie,
Tell your mechanic to look it up under 1985 Chevy Truck P30 with a 454.
Any NAPA, AutoZone, PepBoys etc will have one. There are typically two versions; one is a pressure sender and one is a switch for the idiot light. I replaced both of mine just for good measure. Neither was expensive.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 09-20-2006, 07:15 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Delco part number is U1801A for the sender with the light, and D1829 for the sender with the gauge.
Old 09-21-2006, 08:27 AM   #5
str8strm's Avatar
I knew someone would know!!
AIR 7992
Old 09-22-2006, 06:56 PM   #6
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
hmm... watch your wallet with that mechanic. Not sure I'd be spending quality time with someone who didn't recognize a 454 Chevy when he saw one....let alone quality money! Parts for our chassis are easy to find and if you look close they don't have to cost an arm and a leg. The best consumer is an informed consumer!
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 09-22-2006, 07:55 PM   #7
noiva's Avatar
Chesapeake , Virginia
Images: 46
Glen,
That's easy for you to say. Try finding the same for a 370 Gillig. The engine and tranny are fairly simple, but the rest of the info wasn't barely mentioned even in the Airstream manuals. Keeps saying to "see Gillig manual".
I guess if you want a full-sized Blimp, you have to expect certain inconveniences when you go for parts .
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
noiva is offline   Reply With Quote
Unit Rally jcanavera WBCCI Rallies & Events 0 08-18-2002 09:15 PM
Armstrong AC unit pics FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 8 08-05-2002 03:26 PM
Removing the Armstrong AC unit FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 11 08-02-2002 11:10 AM
oil and trans fluids ALANSD Airstream Motorhome Forums 22 08-01-2002 02:47 AM
Need info on A/C unit on a 1975 26 ft Argosy ... Hayseed Argosy Motorhomes 0 06-27-2002 08:19 AM
