Old 04-09-2006, 07:09 PM   #15
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Originally Posted by scf31
How about that Filter Mag !!!! check for metal slivers and particals after a oil change, I need one !!!!!
I've been running the Race FilterMag on the full flow Amsoil filter side of my dual bypass oil filtration system. It sure helps. I also run the Mag-Hytec rear diff cover which uses a magnetic drain plug and a magnetic screw-in dipstick. I just checked the stick this morning after a trip and wiped the stick clean. It hasn't been checked in 5,000 miles so I was pleased that there was only just a little metal seen. Next addon will be the Mag-Hytec Allison transmission plan for extra capacity. With 53,000 miles it is time to replace the inner filter most people don't know about.
Craig
AIR #0078
3.73 rear end
Amsoil synthetics all around
