Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 10-11-2013, 09:51 AM   #21
Wise Elder
Jammer's Avatar
2010 30' Classic
Another way that mod is sometimes done is, instead of a switch, just put in a receptacle for the 20a side of the generator. Then plug into that for generator or connect an extension cord if using shore power. Breaks both hot and neutral and the switch is never in the wrong position.
Old 10-11-2013, 07:32 PM   #22
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
I agree with Jammer in post 16. Instead of using the SPDT switch, I would have went with a DPDT (double pole double throw). This way you would be separating the neutral as well. It's easy to change. Just add another white wire & do what you did with the hot black wire.
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 10-11-2013, 09:45 PM   #23
Stream Weaver
romakdaddy's Avatar
1989 37' Airstream 370
pamplico , South Carolina
Send a message via Skype™ to romakdaddy
I see what you are saying and its a good idea but Lowes didn't have any dpdt switches that I could find...might try one from the internet I guess.
romakdaddy is offline   Reply With Quote
Old 10-16-2013, 06:44 PM   #24
A proper DPDT switch with the right rating costs about $60. I did the same mod as 3 Dog Nite and it works like a charm. Highly recommended.
Here is the DPDT switch switch I used.
1975 24' Argosy Motor Home
Old 10-22-2013, 01:46 PM   #25
Stream Weaver
romakdaddy's Avatar
got the right switch and I must say...it wasn't cheap.got one local for 70 bux and installed it the next day...I shouldn't have to worry now cept getting the front unit to cool...lol
Old 10-22-2013, 06:32 PM   #26
wxbuoy's Avatar
Wildwood , Florida
Send a message via Skype™ to wxbuoy
Maybe I am missing something or have a different set up (350). I have a SPDT switch that lets me choose whether to run the front or rear A/C when on shore power (both are fed on Generator). Is this the same on the 370?
Because, even if you used a DPDT switch on the Generator feed to the front A/C it is still not isolated since it shares a neutral on the SPDT switch to choose which A/C to run.... So wouldn't you also need to replace the A/C selector switch with a DPDT switch as well?
I could be wrong, and often am, but I was hoping to do the same mod and was looking at the wiring diagram in my manual.
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 10-22-2013, 06:48 PM   #27
Dave,
Refer back to posts #17 and #18. The purpose for installing the switch is to allow running both air conditioners while connected to shore power. Typically these motorhomes are set up to allow only one of the two to run at a time on a 30 amp circuit.
What the switch does is allow you to bring in a separate 20 amp shore power cord , connect it to one side of the switch, the generator feed to the other side and the output goes to the rear a/c unit transfer switch.
With the switch in one position the a/c unit is powered from the generator (or factory shore power). In the other position it's powered from the new 20 amp shore power cord. This allows you run the front a/c unit via the rotary switch that selects which a/c unit, front or rear.
I have a sketch of how I did the wiring change on the 310. If I can dig it up I'll send you a copy.
All in all it's a nice wiring change to make.
Old 10-22-2013, 07:30 PM   #28
wxbuoy's Avatar
Wildwood , Florida
Brad,
I still don't see it. I understand the purpose, but fail to see how the Rear A/C gets a neutral if not tied together somewhere. Since the switch is a SPDT switch the hot is being shifted. But where are the A/C's getting neutral if not tied in. There are 2 Generator neutral ties ins on the main breaker panel and a magnetic transfer switch to switch the hots. I need to look at the switch over relays for the main and rear A/C again.... I am also going to go into the electrician at work ans say "splain this to me".
Dave and Felicia
Old 10-22-2013, 08:36 PM   #29
Stream Weaver
romakdaddy's Avatar
on the 370 the front ac is only connected to the 20a side of the genny(most gens output 2 110v circuits) on the gen one side(30a) powers the coach side,same as the main shore cord. the other side(20a) is only connected to the front ac.there was no way to run the front unit without running the gen so I fixed it so I can run it from a drop cord connected to another 20a outlet.hope this clears it up.
Old 10-23-2013, 05:44 PM   #30
wxbuoy's Avatar
Wildwood , Florida
Thanks, that makes sense. On my 350 I can run both on generator and choose the front or the rear A/C to run via a SPDT switch the factory installed. I guess I need to pull the switch to see what it is doing so I can understand Brads point.
Dave and Felicia
Classic vs Classic limited Flying Gypsies 2006 - 2010 Classic (all lengths) 13 10-15-2011 06:37 PM
2003 Airstream Classic 30 Ft. EXCELLENT!!!! S2003 Airstream Classic 30 Ft. EXCELLENT! eBay Watch Airstreams on eBay 0 07-13-2011 12:00 PM
Classic -vs- Classic Limited 10Smiles Dollars & Cents 11 06-22-2011 08:33 PM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 07:20 AM
