Old 06-30-2016, 06:28 PM   #1
1987 34.5' Airstream 345
KC , Missouri
Noob airhorn question
I have air horns on my 345.... but I have no idea where that "button" to activate them is, I presume it's different than the horn button in the center of the wheel - regular horns work fine.
Thanks!
DHC1 is offline   Reply With Quote
Old 07-02-2016, 07:53 AM   #2
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Thanks!
While they may look like air horns, I think you'll find them to be electric horns instead of air horns; at least mine were. They would be driven from the horn pad in the steering wheel, but people like my PO have had issues with the connections to the horns and since replaced them with ones under the hood.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 07-02-2016, 11:17 AM   #3
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Even my electric 'air' horns don't work properly. I've bought a great set of real air horns, as well as a cheap air horn Harbor Freight air horn system. Figure pump will go in upper cab cabinet, air hose to roof, wiring already there. We'll see, thinking of 'acquiring' another project tomorrow as well lol
Old 07-02-2016, 04:39 PM   #4
KC , Missouri
You guy are correct. after further looking they are electric without an air side. Not sure worth the effort to fix when a couple of Fiamm's will honk the hair off your head if you're in front of them.
Thanks!
Kurt
Old 07-02-2016, 08:06 PM   #5
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
The PO added electric horns because the Hadley Air Horns must not have been working. I did a systems diagnosis, dismantled the air horns themselves, and they were full of debris. I blew them out, and reassembled. I then checked the electric, and for whatever reason the solenoid for the air horn was disconnected. I reconnected it, tested the system. Verified resistance, current, and voltage to ensure it was not a preventative measure. It looks like someone was working on the rig and just forgot to reconnect it. So I have fully functioning air horns, and electric horns. When I press the horn I get a loud blaring from a total of four horns. Two electric and two air. It scares the bejoobers out of people who try to get too close to my rig. And truth be told, I like it, because their reaction is to move away.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Total Noob towing question johnnykim22 Hitches, Couplers & Balls 2 04-18-2016 06:27 AM
Noob question Otto2006 Member Introductions 2 09-07-2009 04:52 PM
Another noob here! DMRK Member Introductions 6 04-26-2008 09:55 AM
Florida Noob SLVRSRFR Member Introductions 2 06-12-2007 11:39 AM
