Old 07-30-2016, 01:23 PM   #1
1975 25' Tradewind
1986 34.5' Airstream 345
Lewiston , Idaho
No power to battery isolator and ignition
Hi,
I just pulled my 86 345 from two years of storage. After putting new coach and engine batteries in I found that I had NO power to the ignition switch and no power to the isolator on the firewall. I would expect the isolator to be hot as it is a direct line from the battery solenoid.
I do have power to the generator and the starter and all grounds are clean, tight and in good condition.
So, I think the problem is the solenoid on the back of the battery compartment. Before I start tearing thing apart I would hoping for some feedback thoughts on this problem.
thank you
Patrick
flash is offline   Reply With Quote
Old 07-30-2016, 01:35 PM   #2
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Pull the toggle switch in the glovebox to couple all batteries together and see what happens. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 07-30-2016, 01:38 PM   #3
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Check to make sure you didnt switch off your battery disconnect switch. (if so equipped) its happened to me more than once. My battery disconnect switches are in the stepwell of my 310, dont know location on a 345.
mayco is offline   Reply With Quote
Old 07-30-2016, 01:40 PM   #4
1975 25' Tradewind
Lewiston , Idaho
I tried that before I stared checking for power from the solenoid and got the same results. I checked the isolator for juice with the toggle switch pulled(helper needed) and still no power to the isolator.
So, no power to isolator from engine or coach batteries has me thinking the solenoid is the issue. Starter and generator power a wired direct from the input side of the solenoid and they are hot.
thanks
Patrick
Old 07-30-2016, 01:54 PM   #5
bobmiller1's Avatar
I would go over the wiring you disturbed while you changed the batteries and check your grounds with a test light. You will find your problem. Regards, Bob
Old 07-30-2016, 02:04 PM   #6
1975 25' Tradewind
Lewiston , Idaho
All the grounds are good. Cleaned and tested while tracing NO power to isolator.
Old 07-30-2016, 04:52 PM   #7
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
I imagine that you have checked this, but we had a broken cable terminal at the solenoid that caused all kinds of problems. It would shift around every time the battery drawer was opened and closed.
Waipio Rim is offline   Reply With Quote
Old 07-30-2016, 05:17 PM   #8
la nomade's Avatar
2008 16' Safari
1990 29' Airstream 290
stanfordville , New York
no power
i am trying to help my friends (dah) who just got their 310 figure out why,on shore power,light near sink showing power comes in..there is no power in the A.S.
when i run the motor for 15 minn,everything goes on and works fine,then fades out....there are 2 new coach batteries,one new motor battery ,fuses are o.k. what can be draining the batteries???on shore power all should work fine???i have no answer for them..do you???m.v.
la nomade is offline   Reply With Quote
Old 07-30-2016, 05:58 PM   #9
1975 25' Tradewind
Lewiston , Idaho
I pulled the solenoid as I have no other idea on what the root cause is. I found a crack behind one of the posts so perhaps this is the issue. I headed to the local Napa to see if they could find me a replacement. After an hour of looking at their catalogs and online stock I gave up. I found an Intellitic accessory relay part # 77-90000-100 in my search online at Airstream supply. I am going to order this solenoid and see if it fixes my issue.
Patrick
Old 07-30-2016, 11:39 PM   #10
1975 25' Tradewind
Lewiston , Idaho
great,
why don't you start your own thread on your specific problem.
thank you
Patrick
Old 07-31-2016, 05:56 AM   #11
bobmiller1's Avatar
Just curious, inside your entrance door to the right, do you have the wall panel with the two red lights and switches to turn the coach and chassis batteries on and off ? If you do did the switches work before you changed the batteries ? what happens now when you press the switches ? Any clicking noises from either switch ? As you probably already know there are three solenoids mounted to the backside of the battery tray. You should be able to see which solenoid goes to each battery and the third is for the switch in the glovebox. I would remove the grounds from the batteries and make sure the Airstream is "NOT" plugged into shore power then switch the solenoids, IE engine battery solenoid to house battery solenoid and vise versa and see if your problem moves by switching the solenoids. If the problem moves then you are correct and you have a bad solenoid Let me know how you make out. Regards, Bob
Old 07-31-2016, 10:41 AM   #12
What type of clamps do you have on the batteries, i.e. are they leaded clamps with the cables embedded in the lead or are they the clamp on style with a stud sticking out and the cable has an eyelet that goes over the stud?
I had a problem with the clamp/stud style where the stud wasn't making contact with the rest of the clamp! Replaced the clamp and all was good.
Old 08-01-2016, 07:18 AM   #13
la nomade's Avatar
2008 16' Safari
power
they are lead,i made sure they are tightly on....will check the selenoids ,thank you,will keep you posted.
Old 08-02-2016, 10:34 AM   #14
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Just measure the voltage each side of the battery solenoid and at the heavy duty junction block further downstream from that. Fault find from there
Boom Sounds is offline   Reply With Quote
battery isolator/relay Honkity Hank Classic Motorhomes 11 11-18-2010 09:00 AM
Battery Isolator wa3vez Mechanics Corner - Engines, Transmission & More... 5 09-02-2004 12:27 PM
battery isolator kooblekidz Airstream Motorhome Forums 5 08-28-2003 06:04 AM
Battery Isolator thenewkid64 General Motorhome Topics 20 01-12-2003 09:00 PM
Battery Isolator shelocta Airstream Motorhome Forums 1 10-29-2002 10:32 PM
