Old 08-07-2016, 05:40 PM   #15
1975 25' Tradewind
1986 34.5' Airstream 345
Lewiston , Idaho
My 345 is back in business. I ended up changing the Solenoid behind the battery compartment as the original one was cracked and fell apart when I removed it. I also found a bad connection at the starter and lastly I replaced the ignition solenoid in the engine bay as it would not cut power to the starter once the key was turned off. I wonder what is next?
Patrick
flash is offline   Reply With Quote
Old 08-07-2016, 06:02 PM   #16
2007 22' International CCD
No power to battery isolator and ignition
Never ask that. The Airstream gods will promptly smite you with something more difficult😀😀😀
KE4GNK/AE
Old 08-07-2016, 09:22 PM   #17
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Somebody's learning.
Never ponder where trouble is, as trouble will always find you first.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 08-07-2016, 09:29 PM   #18
I'm an engineer. You never, ever tempt fate...
The universe just loves to smack you upside the head if you give it the opportunity or even mention the thought. Murphy was, in fact, an optimist.
My engineering career spans 5+ decades. I learned a few things along the way. I'm the guy they always call when the going gets weird.
(That's when the weird turn pro. Guilty as charged, your honor)
KE4GNK/AE
Old 08-10-2016, 10:15 AM   #19
la nomade's Avatar
2008 16' Safari
1990 29' Airstream 290
stanfordville , New York
it turns out....
it turns out that the no power had to do with the circuit
breaker....we had to trip it and reset it several times,then oh,miracle everything worked,power was back on...but then,on a short week end trip,the convertor went.....this 310 needs a lot of replacements!!! and tlc...also the step motor gave up....but better now then on a long trip...
la nomade is offline   Reply With Quote
Old 08-10-2016, 01:41 PM   #20
If you had to trip the breaker several times like that to get it to work then if you haven't already I would suggest replacing it!
Glad to hear you found the problem.
Old 08-11-2016, 08:14 AM   #21
la nomade's Avatar
2008 16' Safari
thank you...right you are,they have to replace and re -do a lot of the electrical..little by little,with the help of friends and the forum,they will put their 310 back into shape,ready for the road......
battery isolator/relay Honkity Hank Classic Motorhomes 11 11-18-2010 09:00 AM
Battery Isolator wa3vez Mechanics Corner - Engines, Transmission & More... 5 09-02-2004 12:27 PM
battery isolator kooblekidz Airstream Motorhome Forums 5 08-28-2003 06:04 AM
Battery Isolator thenewkid64 General Motorhome Topics 20 01-12-2003 09:00 PM
Battery Isolator shelocta Airstream Motorhome Forums 1 10-29-2002 10:32 PM
