Old 07-28-2016, 06:40 PM   #71
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Kota, excellent point about boost if it was at intake plenum.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 07-28-2016, 10:34 PM   #72
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
Some adventure! Lucky you had Cummins do the work!
SebasSF is offline   Reply With Quote
Old 07-29-2016, 06:43 AM   #73
1995 36' Classic 36
Ludington , Michigan
Richard suggested the heater core(s). And the hot water tank heat exchanger and associated plumbing.
Kota is offline   Reply With Quote
Old 07-29-2016, 07:31 AM   #74
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Originally Posted by Kota View Post
Just some thoughts. I can't imagine any head gasket leak that would allow 1 gallon in 100 miles to get into a cylinder without blowing the cooling system apart. A cracked head between the coolant and intake plenum could be a possibility but I could think you would see some pretty funky stuff coming out the pipe. I'd pressurize the cooling system and see where the water is going. The difference between 1600 rpms and 2000 might be more boost pressure at higher rpms preventing coolant at a few psi from entering the induction system.
When this happens, cylinder gasses over pressurize the cooling system and blows gasses and coolant past the pressure relief valve in the radiator cap.
Gradiens super tenui glacie.
Old 07-29-2016, 07:39 AM   #75
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
What I would do first is to pressure test the cooling system, if this showed inconclusive results I would pressure test using dye.
If you have a compression leak this big, you will smell it in the coolant and or the exhaust.
Old 07-29-2016, 07:51 AM   #76
1995 36' Classic 36
The overflow should be full and overflowing. Should be a wet mess back there.
Old 07-30-2016, 11:57 AM   #77
Vycan's Avatar
Manhattan , Kansas
So, they dyed it, pressure tested it under load, and found cooling system is running at 17psi, causing the overflow out the radiator. Will isolate the air compressor, and determine if caused by engine. i.e. head gasket #3.
Old 07-30-2016, 01:21 PM   #78
HowieE's Avatar
Princeton , New Jersey
Images: 12
Not sure of your comment to isolate the air compressor but if it means they are going to pressure test the system with air make sure they remove the injectors before hand. If the leak is in the engine or head and back pressure is applied the coolant will flow into the cylinders and if started will cause a hydraulic lock. That get real expensive
The significant increase in the leak rate points to the last job as the cause.
2004 Excursion 4x4
Old 07-30-2016, 02:42 PM   #79
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
This is, or has become, an epic adventure to Newfoundland.........pg 6 and Nick hasn't even got out of the US yet.
How long do you have before you're AWOL mate?
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 07-30-2016, 07:50 PM   #80
1995 36' Classic 36
The Cummins has a haldex air compressor that's water cooled. It has two lines that run to the rear of the block. Possible for a failure to pump air into the cooling system.
Old 07-31-2016, 09:17 AM   #81
HowieE's Avatar
Images: 12
Very interesting point about the air compressor. It should be a very easy test to test the coolant side of the compressor for an air leak. Such a failure could move a gallon of coolant in 100 miles.
2004 Excursion 4x4
Old 07-31-2016, 09:22 AM   #82
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
While a compressor leak of this nature is possible, it is very, very, very unlikely.
Old 08-07-2016, 10:21 AM   #83
SebasSF's Avatar
Did you figure out what caused the problem, and is there any advice you can offer to us other diesel 36 owners?
Sebas
Old 08-10-2016, 10:22 AM   #84
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Nick,
How are things going out there??
Charly
streamquest is online now   Reply With Quote
Trip planning to Newfoundland, Nova Scotia, NB SilverEagle6 On The Road... 455 08-09-2017 02:59 PM
Newfoundland stavnes Member Introductions 4 08-13-2007 02:10 PM
Newfoundland HowieE On The Road... 8 07-16-2007 07:44 PM
Store your older AS in Newfoundland PatrickDeBourke Off Topic Forum 11 04-28-2004 01:03 AM
RV travel to Newfoundland and Labrador Ed & Nancy On The Road... 4 09-23-2003 12:51 PM
