Old 07-12-2016, 05:53 AM   #29
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
PM sent to Bob.
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 07-13-2016, 06:37 AM   #30
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Team,
Blown head gasket. Scheduled to be back on the road Thursday. 4 and 5 cylinders were swapping fluids and air.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 07-13-2016, 07:22 AM   #31
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Good news! You have to be relieved that it wasnt something worse. Good on ya!
mayco is offline   Reply With Quote
Old 07-13-2016, 07:29 AM   #32
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Great news; onwards and upwards!
martin300662 is offline   Reply With Quote
Old 07-13-2016, 07:31 AM   #33
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
You're Welcome.
bobmiller1 is offline   Reply With Quote
Old 07-13-2016, 07:39 AM   #34
Originally Posted by Vycan View Post
Team,
It's amazing what seems like such a simple change (injectors) can cause so much grief down the road.
I'm really glad you'll be getting back on the road shortly. Did you ever get your cruise control problem resolved?
Old 07-13-2016, 05:53 PM   #35
bobmiller1's Avatar
Alright, so now we all know it was the head gasket....if you are planning on keeping the same injectors you installed I strongly recommend switching to ARP head studs....this is the reason why. Dodge uses a torque angle method of tightening your cylinder head. If you verify you will see that the torque is equal to about 115 ft. Lbs. if torque. The increased power of the new injectors require more torque....approx. 125 ft. Lbs. You don't have to believe me but if you check with other sources you will see I am correct. I would not re-tighten the bolts that are in there now and hopefully they replaced them because they are stretch bolts and after a few heating and cooling cycles they are subject to breaking if you try to increase torque. Regards, Bob
Old 07-14-2016, 12:57 AM   #36
Vycan's Avatar
Manhattan , Kansas
Team,
Huge relief. Will be glad to get going again.
Bob,
Thanks for the input, have passed along the 125 ft/lb request. They are replacing them.
Old 07-14-2016, 05:59 AM   #37
Dazed and Confused
Isuzusweet's Avatar
Funny thing is, I would just assume that new head studs would be used......People try and re attach diesel heads with old studs???
I guess I'll keep that in mind for the future.
Glad it wasn't something huge....
Cheers
Tony
Old 07-14-2016, 04:31 PM   #38
bobmiller1's Avatar
They don't use studs from the factory...It is common practice to upgrade to studs made by a company called ARP.
Old 07-14-2016, 09:07 PM   #39
Dazed and Confused
Isuzusweet's Avatar
Okay, I didn't know that OEM are only bolts not studs.
Correct me if I'm wrong, but aren't most head gasket problems, head bolt/stud related; i.e. the stud/bolt stretches too much over time relaxing the pressure on the head gasket, causing failure.
It was very prevalent in the Cadillac/Olds Northstar V8 engines, that the bolts actually stripped out of the aluminum block.
http://www.northstarperformance.com/hgfaq.php
Also just curious. How many times should head bolts be retorqued, a) after initial head gasket replacement, b) over the lifetime of a diesel 6BT or 6BD1A/T?
Yes, this BYMDIY, knows just enough to be a danger to all.
Cheers
Tony
Old 07-15-2016, 07:18 AM   #40
mayco's Avatar
If your motor is running well and you dont detect a head related problem, is it worth the risk of snapping a head stud while retorque ing for preventative maintenance purposes?? I was faced with that decision last fall when I had it in for a valve adjustment. I had requested my mechanic to retorque the head to spec and he brought that up. I chose not to have it done. As you know I have pretty limited mechanical skills/knowledge, so Im asking here..
Mike
Old 07-15-2016, 05:36 PM   #41
bobmiller1's Avatar
No re-torquing, period. Regards, Bob
Old 07-16-2016, 10:42 AM   #42
Vycan's Avatar
Manhattan , Kansas
Update, they finished late thursday, we decided to use their provided hookups and head out Friday morning. Made it 130 miles before overheating, oil in coolant, and low oil. At another cummins power shop for work under warranty. Cannot make this up.
Trip planning to Newfoundland, Nova Scotia, NB SilverEagle6 On The Road... 455 08-09-2017 03:59 PM
Newfoundland stavnes Member Introductions 4 08-13-2007 03:10 PM
Newfoundland HowieE On The Road... 8 07-16-2007 08:44 PM
Store your older AS in Newfoundland PatrickDeBourke Off Topic Forum 11 04-28-2004 02:03 AM
RV travel to Newfoundland and Labrador Ed & Nancy On The Road... 4 09-23-2003 01:51 PM
