Old 06-02-2013, 09:35 PM   #1
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Images: 37
New Twin beds in our 310
This is for wxboy.
We changed our double couch layout in the back to 2 twin beds. We had earlier removed the backs to see if we liked the set up, then made the change with hinged plywood and custom mattress'. The mattress size is 32"x76"x5" one medium (for me) and one firm (for the wife). Northern American Mattress Company is where we got them made. Great quality and fast service.
The pads on the walls and the doors, we recovered.
If anyone need the OEM couches, PM me, they can be yours FREE, you will just need to pick em up! Not much longer before they find there way to the dump.
Chris & Brenda, Members of the Christian Motorcyclists Association
AIR Member 12654
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (263,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 06-04-2013, 06:39 PM   #2
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Thanks!!!
Why did you choose the 32X76 size? I was hoping to use a regular twin or single mattress..... I may have to rethink that!
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 06-05-2013, 08:28 PM   #3
woodja's Avatar
Dayton , Tennessee
OK Dave, here are my figures----the interior width @ the head of the aft cabin is 88". At the foot of the beds it's 90" wide X 76" long.
Our mattresses are 31" wide. The frames are 31" wide also but the mattresses could be a skosh wider for sure & I wish they were.
The cabinet between the beds is 19' wide at the base & maybe 3" wider at he top.
I don't know the width of a standard twin but you might make it work without
the useable 3 drawers between the beds.
I'm sorry I didn't measure the aisle width between the beds but you should get a feel from the pics-----if I'm able to upload. One more rum should help.
ID:	187521   Click image for larger version
ID:	187523   Click image for larger version
ID:	187525   Click image for larger version
woodja is offline   Reply With Quote
Old 06-06-2013, 04:32 AM   #4
wxbuoy's Avatar
Thanks Pete that helps allot!!
Now I have to go over and lay it out..... I can easy sleep on a cot size mattress (30X74) since that is the size of the racks on most of the ships I have been on. But I do like the idea of using an off the shelf Tempur-Pedic for my back.. which is 38X74. But that would only leave a 12" isle.....
So I guess the only thing to do is do it backwards! Get the mattress, most likely a 32X74 and build the frame to match.
I am going to call the place Chris suggested and a place that specializes in mattress for boats (custom sizes and shapes) and start pricing them.
Although twin bunk beds would work..... but they would quickly become impracticable and inconvenient.
Dave and Felicia
Old 06-08-2013, 10:17 PM   #5
cmadmaxman's Avatar
Images: 37
Dave, I would keep the bed as long as possible. Anyone over 6' tall will have a problem with that 74". I wanted to go the 80" (which is the wall to wall length) but settled for the 76" and that keeps room to make the bed easier. Like Pete said, would be nice to go wider, but if you look at a Queen bed, they are 60" wide, so if you keep to your side, you have about the 30" of sleeping area. Going wider will take out your aisle real quick. I could have gone to 34 wide on the mattress, but with the curve in the back, they would have stuck out past the edge, or they could have made a curved mattress, but did not want to do that. You can go thicker, but ours with memory foam sleeps well. I would go with the regular mattress material, and not the blue standard they use. Its hard to keep sheets on. We just got some custom mattress covers, so will see how that goes. They were about $60 each.
AIR Member 12654
1982 310 MoHo
Old 06-09-2013, 05:46 AM   #6
wxbuoy's Avatar
Chris, thanks for the advise! I am tentatively looking at either a 30X80 or 32X80. I need to check and make sure I have the space, but would like to stick with a size that we can easily get sheets for. I am headed over to measure things out when I get home today.
Dave and Felicia
Old 06-09-2013, 10:58 AM   #7
1995 36' Classic 36
Ludington , Michigan
I like the looks of your floor with the wood installed crossways. Does it make the interior look wider? Could you post some pictures?
Thanks.
Kota is offline   Reply With Quote
Old 06-09-2013, 11:45 PM   #8
1989 34.5' Airstream 345
Silverton , Colorado
FWIW...cutting foam is really easy with an old electric knife...
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 06-10-2013, 03:25 PM   #9
woodja's Avatar
Dayton , Tennessee
Twins
Dakota
Notice, after starting to cut quarter round trim I switched to hemp rope
about 5/8" hardware store stuff. Held in place mostly with a dab of silicone
here & there.
I don't know if it feels wider but it seemed logical to me & apparently to Chris also.
ID:	187868   Click image for larger version
ID:	187870   Click image for larger version
Old 06-11-2013, 09:02 AM   #10
cmadmaxman's Avatar
Images: 37
Pete's rope trick looks great!
I took out the table plastic thingy from our living area, so had a straight wall there I could trim. When I can get my phone to download to the computer, I will post you some new photos of the floor.
We used tongue and grove bamboo and found that it machines great! I milled slots for vents and made custom trim as well as switch mounts for the wall.
Like Pete, we liked the layout of the cross-ways look better than the long ways. Although there is more cuts, I think it is easier to fit. We glued ours down.
AIR Member 12654
1982 310 MoHo
Old 06-11-2013, 12:06 PM   #11
cmadmaxman's Avatar
Images: 37
Bamboo floor
Got my phone to download.
Here is some shots of the bamboo flooring. We used it for the kick area under the couch, sink, and rear beds. Used the bamboo 1/4 round in other areas and used SS screws to hold them in place. All the step well can be removed with SS screws holding the pieces in place. The flooring came pre-finished and the parts that I made used polyurethane to seal it back up.
ID:	188022Click image for larger version
ID:	188025Click image for larger version
ID:	188032Click image for larger version
ID:	188034Click image for larger version
AIR Member 12654
1982 310 MoHo
Old 08-01-2013, 07:08 PM   #12
wxbuoy's Avatar
decisions....decisions..
Chris, Pete, et al,
Well I have finally had time the last few weeks to work on the moho on a limited basis. We were too busy the first part of the summer going camping then the 25th anniversary in July... So finally back to the grind stone.
Here is a shot of what I have done so far. The bedroom is completely empty and the mouse fur stripped off the walls and overhead. We are waiting for some special order wall paper (textured vinyl that looks like brown leather). Don't say a word... sometimes you just have to say "yes dear"!
I plan on coating the floor with WEST epoxy to seal it. The only problem is I am in an infinite loop trying to decide between 30" mattress and 32"....
The blue chalk lines are laid out at 32" which is perfect match to the hallway and would allow 1" either side for sheets, blankets, etc... and a 22" isle. How ever, If I tweaked it out 2" on each side I would get a 32" mattress and still have a 18" mattress. However with the curve of the back end I would have a gap of 13" at the head of the bed.... Unless I angled the heads of the bed together like they do on boats. that would make the head narrower but the berths wider. Allowing me to slide the mattress forward so I have the 13" of space at the foot of the bed, and still plenty of room to change, etc.
Anyone have any thoughts? I kinda like the boat idea....
Name:	GOPR0777 (Medium).JPG
Dave and Felicia
Old 08-01-2013, 07:22 PM   #13
wxbuoy's Avatar
Kinda like this...
Dave and Felicia
Old 08-02-2013, 05:57 AM   #14
woodja's Avatar
Dayton , Tennessee
Dave, I would go with the wider mattress configuration. The drawers between the bunks are rarely used & I'd rather have wider beds & a narrower
cabinet. I think we have too much space on either side of the mattress for tucking in sheets, etc. If our mattresses are 31' wide, I wish they were 33'.
Glad to see you're making progress------------------------P
