Old 06-07-2012, 12:11 PM   #1
1979 28' Airstream Excella 28
Commerce , Michigan
New to the Forum
Hello everyone I just decided to register after following this forum for a year or so. I find the people here to be most helpful and freindly. I've owned a 1979 28 Excella now for 12 years and have a terminal case of aluminitus just like everyone else here. I've done many of the same repairs and upgrades as many of you have and hope I can be of some help to others here. I work in powertrain engineering for the automotive and trucking industries in Michigan.
Looking forward to being part of the forum
DA TAZ
DA TAZ is offline   Reply With Quote
Old 06-07-2012, 01:06 PM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Welcome! Your expertise and offer of help is appreciated.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 06-07-2012, 01:19 PM   #3
SteSpot's Avatar
1968 28' Ambassador
1982 24' Airstream 240
Ventura , California
Welcome to the forums.
We have a 1982 24' Motorhome that we are in the process of bringing back to a useable motorhome. We have a 454 7.4 L Chevy engine on a P30 chassis.....living in California, we had to bring her back to her original smog equipment.....not an easy task....but we were able to get her smogged and licensed....now we are concentrating on the inside.....if you change this, well we might as well do that......welcome again and please post some pictures...paula
Paula & Ed
Suite Spot
WBCCI # 8252 Air#13593
1968 28'Ambassador
2011 GMC Yukon Denali
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 06-07-2012, 02:30 PM   #4
Commerce , Michigan
I to have a p30 454
My current project is going all electric on the engine cooling fans.
Old 06-07-2012, 03:51 PM   #5
Mike Leary's Avatar
Images: 11
You obviously have a 454. Geez, those engines with the crappy manifolds got hot; cook a steak in 3 minutes. I have heard that Banks built a better manifold/ exhaust system that helped.
Old 06-07-2012, 09:49 PM   #6
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Good idea to use it for cooking! I love those old motorbikes... Maybe someday!
Skatiero is offline   Reply With Quote
Old 06-07-2012, 09:49 PM   #7
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Duh, not bikes!
Um, motor HOMES. Darn autocorrect!!!
Old 06-07-2012, 11:23 PM   #8
1989 34.5' Airstream 345
Silverton , Colorado
There is a cookbook, probably available at Amazon, titled Manifold Destiny...all about cooking on the engine block while headed down the road...my '63 Chevy fed me a warm/hot meal many times, although I would prefer not to remember the time the can of beans exploded...WHAT A MESS!!! This book informs you of how to foil wrap stuff, where to place it for best cooking, and when to stop and turn it...entertaining reading, even if you don't try it...
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 06-08-2012, 08:01 AM   #9
Commerce , Michigan
I think i'll stick with the BBQ I've done it snowmobiling and i dont like the taste of 10w40
Old 06-08-2012, 09:05 AM   #10
Gainesville , Florida
Used to do hotdogs on the cylinders of old BMW boxer twins. Jim
Old 06-09-2012, 07:28 PM   #11
Surprise's Avatar
1984 31' Airstream310
Surprise , Arizona
I was looking through some old paperwork from Airstream and found a letter admitting that on the passenger-side exhaust manifold there was a design flaw that caused the exhaust manifold gasket and doughnut gasket to fail prematurely! This flaw being the Steel Panel in the wheel-well blocking airflow and essentially trapping the hot air. This is for the 310/454ci varient. I'm sure other models as well!
I'm considering notching out a piece of this panel and bending it out to funnel some air to this area. Just thought I'd add my own observation!
Surprise is offline   Reply With Quote
Old 06-10-2012, 04:22 AM   #12
Commerce , Michigan
I have seen that manifold glow cherry before i added a trans cooler which required a large hole thru the wing panel. I also had the radiator redone about 4 years ago and went to 4 cores now even when i tow my boat im lucky if i can reach the thermostat on cooler days. The main reason i m going all electric on the fans is noise. The stock cluch fans can engage harshly and a toss the belts and flex fans are noisey------huh-----
Old 06-10-2012, 04:56 AM   #13
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
Welcome to the forums!
It seems by your post that you have an understanding of mechanical things, good!
It will be interesting to see if you chime in on some of the more "mechanical" debates that sometimes happen here. In general there is a nice group here and the forum is a lot of fun!
Bruce
Bruce B is offline   Reply With Quote
Old 06-10-2012, 05:40 AM   #14
Commerce , Michigan
Thank you Bruce B. I see another thread on fridge repair has started. When mine failed 3 years ago i went to a convensional compressor type with an inverter could not be happyer with the preformace. Ill post some pics and duity cycle info soon.
