Old 12-15-2015, 01:39 PM   #1
1987 34.5' Airstream 345
KC , Missouri
New to me 345 - picking up Monday
We're the new owners of a nice 345 and are very excited about it. I have a couple of easy questions: 1) Air pressure recommendations for front airbags, 2) Recommended tire pressures.
Thanks in advance for your feedback.
DHC1 is offline   Reply With Quote
Old 12-15-2015, 01:50 PM   #2
Bethany533's Avatar
1983 30' Airstream 300
Covington , Louisiana
Congratulations!! Looks good
Bethany533 is offline   Reply With Quote
Old 12-15-2015, 01:53 PM   #3
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Absolutely beautiful!!
Congratulations, and have a safe trip.
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
Blessed and highly favored
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
PaulnGina is offline   Reply With Quote
Old 12-15-2015, 03:16 PM   #4
You've got a great looking 345 there and welcome to Airforums!
Front airbags set to 55 psi. As far as tire pressures hopefully a 345 owner will chime in with the pressures they use.
Old 12-15-2015, 03:31 PM   #5
KC , Missouri
Thanks for the feedback, we're excited and I look forward to participating on the forum. 55psi for airbags - great. I am assuming 45-10 psi on tires, but open to info there.
Old 12-15-2015, 05:01 PM   #6
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Try 70lbs in the tires to start with I run 80lbs in mine all round. Maybe someone else will chime in
shepherd57 is offline   Reply With Quote
Old 12-15-2015, 05:50 PM   #7
1989 34.5' Airstream 345
Ebro , Fla Panhandle
The PO of my 345 went with the max recommended pressure indicated on the tire. 90psi, I found this too hard and settled at 70/75 psi.
and using a lazer thermometer I haven't found any high temps in the tread or sidewalls. A bit softer ride with the lower pressure.
Welcome to the forum and Congrats on your new coach, looks nice. Keep us posted on your projects and adventures.
Cheers Richard
tevake is offline   Reply With Quote
Old 12-15-2015, 06:00 PM   #8
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Yes, I was surprised when I found my Airstream tire pressure placard that stated 70lbs all around for tire pressure. I tend to err on the side of caution and run 75-80lbs.
Make sure the rear air ride works as that could take a toll on your tag axle.
Nice find and we all wish you luck in keeping this queen of the road, on the road for a long time.
Cheers
Tony
Old 12-15-2015, 06:02 PM   #9
Richard, I can sympathize with the 90 psi pressure issue. On my 310s trip home after purchase I had to have the spare moved over to the left rear inner dually and since I didn't have the proper tools with me we called RV Road Help. They came and swapped the spare over to the inner dually and pumped all the tires up to 110 psi.
Darn thing road like a log truck until I dropped the pressure to around 70 or so.
Just because the tires are rated for a 110 psi doesn't mean they should be used with that high a pressure!
Old 12-15-2015, 06:02 PM   #10
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
65-70 front and 80 rear. Like Richard says, it makes for a little softer ride on the front.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 12-15-2015, 06:19 PM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
That looks like a real "find"!! Congrats!
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-15-2015, 06:20 PM   #12
KC , Missouri
Thanks for the info on tire pressures! Rear airbags have been replaced within the last two years, I presume there's a bit of life left there.
PO paid a lot of attention to maintenance and preventive maintenance. Can't tell you how happy I am about that. Comes with all the manuals on the vehicle, and all systems plus maintenance records since new. I'll have a lot to dig through. I will also say that if anyone want info from a manual, let me know and if I have it. I'll try to get it scanned for you.
Old 12-15-2015, 07:26 PM   #13
northern IL , Illinois
Looks very nice in the picture. Lucky you got 007 briefcase with it. I keep mine right next to my lazy-boy for safe keeping and late night reading. Welcome to the nut house.
Hans 34.5 is offline   Reply With Quote
Old 12-15-2015, 08:14 PM   #14
Looks fantastic!
Welcome to the madness! ROFL
Keyair is online now   Reply With Quote
Picking up my baby Monday thecatsandi Axles 23 05-26-2011 08:35 PM
Our full time adventure begins on Monday! zombyw00f Full-Timing 18 12-13-2007 09:38 PM
Maintenance: Monday 12, 2007 Andy R Forum Admin, News and Member Account Info 47 03-18-2007 03:32 PM
Our visit to AS factory last Monday (photos)... crazylev Our Community 6 03-20-2003 04:35 PM
