Old 12-18-2015, 04:13 PM   #43
Originally Posted by DHC1 View Post
I once had a Fiat 850 Spyder, I am still amazed that it functioned as my only car for a year. When I replaced the clutch, I could lift the engine out by my self, with my hands/back/etc. Ate starters like they were candy.
Dang, I had an 850 Spyder also! Drove it for about a year. It was great in the winter being rear engine and flat on the bottom. It basically just slid over the show while the tires were in the ruts!
I went from the Fiat to Triumphs and have never looked back
Old 12-18-2015, 05:39 PM   #44
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
OK, DHC1, back to business. Here is the reality check:
a "partial" list of items I fixed on my first Airstream MH
ID:	254087   Click image for larger version
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 12-18-2015, 06:12 PM   #45
1987 34.5' Airstream 345
KC , Missouri
Peter! You're spraying gas on the fire of my "what the hell's going to happen" anxiety! Hehehe. As long as I don't have to complete the list before getting home, I can deal with it. After all, I went from the Fiat, to MG's, to V12 jag's, and on top of the heap - Range Rovers. I am a glutton....
DHC1 is offline   Reply With Quote
Old 12-18-2015, 06:22 PM   #46
Airstream Driver
1997 30' Excella
Images: 51
That anxiety is part of the deal and will become your best friend.
How far do you have to drive to get her home?
1996 Airstream B190
AIR #13
Old 12-18-2015, 06:30 PM   #47
KC , Missouri
I agree with you, I'll be plenty alert. Looks like about 960 miles. As far as how long I'll drive per day, I'll just play it by ear, hopefully I'll get to make the choice and not the 345 . I don't plan on pushing too hard, no reason to.
Old 12-18-2015, 06:42 PM   #48
Airstream Driver
1997 30' Excella
Images: 51
thats a nice little run, you will have a blast!
one real good tool to carry with you is a laser heat gun. check your tires and wheels at every stop, overheating can alert you to potential underinflation or wheel bearing/brake issues. It is also a fine tool to check your engine temp at various locations.
I am sure you did already join Good Sams or similar?
1996 Airstream B190
AIR #13
Old 12-18-2015, 06:50 PM   #49
KC , Missouri
Good idea, I'll take the thermometer with me. Have joined Good Sam - Thanks much.
Old 12-18-2015, 06:59 PM   #50
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Whatever you do don't ignore the fellow motorist that is halfway out of their car with fear in their eyes, arms making explosive gestures and that nagging little voice in your head that's telling you........ something maybe amiss.
V12 Jaguars eh, glutton may not be the word I'd be looking for to describe you. I was smart in not buying a V12 for the wife and stuck with the AJ16 straight six. My wife is the type that when things are going south.....she drives faster.
Goodluck with the drive.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 12-18-2015, 07:14 PM   #51
KC , Missouri
Cheers
Tony
Hehehe - my sister is like that.
Old 12-19-2015, 05:07 AM   #52
Airstream Driver
1997 30' Excella
Images: 51
laser thermometer and tire pressure
Some of the very knowledgeable tire people on this forum have made me aware of a proven way to check if your tire pressure is within reasons.
Since you received so many different inputs regarding pressure, you may want to use this:
If your tire temperature increases by 10% or more, you tire pressure is too low.
So, i.e. if you run the manual suggested rear pressure of 60 PSI and after a good run (especially in the summer heat), your pressure would read 67, your initial cold tire pressure is way too low and you are hurting your tires and are risking tire failure.
1996 Airstream B190
AIR #13
Old 12-19-2015, 06:15 AM   #53
Cheers
Tony
When checking tire temperatures the sooner you check them after stopping the better. They can cool down fairly quickly and give you a false indication of what's really happening.
I learned that while crewing for a vintage race car. The driver would pull off the track into the hot pit lane and I would jump over the wall and take quick readings and then the car would head back out onto the track again.
Old 12-19-2015, 02:21 PM   #54
Thats great info... I will add a IR thermometer to my travel kit until I can splurge on the temp and pressure monitors.
Oh, and to prove my insanity... Here is my GF's Daily Driver...
Old 12-19-2015, 07:13 PM   #55
Dazed and Confused
Isuzusweet's Avatar
So......are you implying that your girlfriend is insane? Careful.
Cheers
Tony
Old 12-19-2015, 08:12 PM   #56
Cheers
Tony
Well, she loves me..... so what does that say?
Picking up my baby Monday thecatsandi Axles 23 05-26-2011 08:35 PM
Our full time adventure begins on Monday! zombyw00f Full-Timing 18 12-13-2007 09:38 PM
Maintenance: Monday 12, 2007 Andy R Forum Admin, News and Member Account Info 47 03-18-2007 03:32 PM
Our visit to AS factory last Monday (photos)... crazylev Our Community 6 03-20-2003 04:35 PM
