Old 08-22-2017, 02:52 PM   #1
1991 35' Airstream 350
Windsor , North Carolina
New tires for the Zepplin
I checked the subforum for axles, wheels & tires--there wasn't much there. But I really need some info on replacing my 14 year old tires. What's on it now is Bridgestone 8R19.5 12 plys. While I can still get 8R19.5's from one or 2 manufacturers, I am told that, should I have a problem on the road, nobody that does road help is likely to have a tire that size to mount. A tire vendor has recommended that I use 225.70/19.5, which will have a slight effect on my odometer/speedometer, and there should be about .75 inch of space between the tires on the duals. Has anyone done this, and, have there been any problems??
Second question: Does anyone have any experience, good or bad, with Sumitomo or Yokohama tires. I really like Michelins, but I'm buying 9 of them, so a cheaper alternative is a requirement, at $400-$550 a tire.
Thanks in advance
Rob
ralley is offline   Reply With Quote
Old 08-22-2017, 03:19 PM   #2
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
There's a pretty thorough discussion here: http://www.airforums.com/forums/f311...ave-99465.html , with a link to a second thread. Several members expressed concern about the clearance between the dualies as well as clearance between the tag tires and inner fender with 225/70r tires, but at least one reported having made the switch with no problems. I put 225/70r tires on my steer axle last year and like them.
Waipio Rim is offline   Reply With Quote
Old 08-22-2017, 03:45 PM   #3
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I am running the Michelins on the 370LE, spend the money, you won't be sorry, Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 08-22-2017, 03:51 PM   #4
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Mr Bob, what size tires are on your 370? I don't think Michelin make the XRV in 8R19.5" anymore. Other than Chinese tires, Japanese Toyo MZ120's and Korean Hankook AH11's. I think that's it for 8R19.5 tires. I could be wrong though.
Cheers
Tony
Old 08-22-2017, 07:44 PM   #5
bobmiller1's Avatar
P225/70R19.5 XZE, Tony
Old 08-22-2017, 07:45 PM   #6
bobmiller1's Avatar
Check out the pictures on the 370LE Start to finish thread. Regards, Bob
Old 08-23-2017, 06:19 AM   #7
Mentor , Ohio
I just recently had the Michelin P225/70R19.5 XZE tires installed on the 350LE. Seem to ride a little nicer than the old tires. No problems to report.
dspaw is offline   Reply With Quote
Old 08-23-2017, 11:23 AM   #8
jkwoodrow
1987 34.5' Airstream 345
Springfield , Ohio
I recently had 8 new Firstone 225s installed on my 345. No interferance issues. The new tires made a big improvement in ride, handling and especially safety.
John Woodrow is offline   Reply With Quote
Old 08-23-2017, 01:13 PM   #9
gaiaenviro's Avatar
1987 32.5' Airstream 325
dripping springs , Texas
At the opposite end of the spectrum, I'm running Sailun S737's on the rear and Hercules H-803's on the front. Both sets are 225/70 19.5 without any rubbing issues. Both sets are also aggressive tread patterns (similar to an all terrain LT tire) as opposed to radially grooved. I purchased the front set in the middle of nowhere (Iraan, TX) after a blowout, and they were the only choice I had. The rears were purchased locally, but I live pretty far out, so again had one choice that I could get installed in a day, and my work load prevented waiting for a week. I've put about 15,000 miles on the set in the last year and a half without issue, including a few 3000+ mile trips, in all sorts of weather. For what it's worth I also run centramatics and bilstein shocks. I also start and end every trip with 2 miles of gravel road and 3 cattle guards to get to pavement. Good luck!
gaiaenviro is offline   Reply With Quote
Old 08-23-2017, 01:24 PM   #10
bobmiller1's Avatar
Wow.....and I thought I had it bad leaving my place !
Old 08-24-2017, 12:42 AM   #11
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I've been running Goodyear G647 in size 8Rx19.0 for years and never had a problem finding them. They are 12 ply and mud and snow rated, M+S molded in the sidewall. I live only 1/2 mile up a dirt road but put many dirt miles on in Alaska a couple of years ago. Steers well and ride is comfortable. Current cost is listed at $331 and I run Dyna-beads for balancing.
Cheers, Dan
~ Margaret Thatcher ~
Old 08-24-2017, 06:56 AM   #12
bobmiller1's Avatar
Yeah...the dyna beads are definitely the way to go....put I think 6.5 ounces in each of the 9 michelins.....rode smooth all the way down to Lancaster, PA and back. Regards, Bob
manufacturer tires to new tires Panchopaco Tires 5 08-15-2017 10:37 PM
Tires...Tires...Tires Bob Thompson Tires 277 07-30-2015 02:30 PM
Tires ready to blow out! Should Marathon tires be outlawed? marchesi Tires 21 08-22-2009 11:11 AM
Help tires, tires, tires. jimmini Tires 9 10-18-2008 08:54 PM
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 05:11 PM
