Old 07-05-2007, 04:43 PM   #1
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
New or rebuild dash AC?
Just got my baby smogged...failed first time due to too rich, but they adjusted the Edelbrock 4 barrel and it passed the second time. However, as they were running the engine, an awful noise was coming out of the front of the moho and the doghouse. The mechanic said it was the condenser clutch bearings starting to go. If it failed while driving, the belt would rip off but it would not affect anything else. Should I have it rebuilt or are there replacements for this type of thing?
1992 Airstream 300LE, rear queen, Banks Power!
Astrodokk is offline   Reply With Quote
Old 07-05-2007, 08:31 PM   #2
My wife had the same diagnosis on a 93 Cadillac that she just picked up. The mechanic said the compressor clutch bearings and the idler pulley bearings were shot. Cost is going to be around $225 to fix (parts and labor). That is about what you would pay for a new A/C compressor with clutch not including labor.
I'd say get the bearings replaced. That way they don't have to break into the A/C freon lines and you don't have to pay for the freon work.
Just my $0.02
Old 07-06-2007, 03:50 PM   #3
ranchmink's Avatar
1979 28' Airstream Excella 28
Bakersfield , California
Good point,
I agree that changing the clutch and bearing make sense. If you lived in California they would require you to recover the refrigerant and if you can get the R12 or whatever you have in will most likely pay a premium for the clone or replacement refrigerant.
I just changed my entire system to R134 with a sandon compressor. It works well with a new complete AC system.
The only down side is new compressors are more efficient except R134 is used mostly but your hoses and seals would have to be changed. Keep it simple...........
Chris Addington
Central California
1965 Tradewind Trailer
1979 Airstream Motor Home
ranchmink is offline   Reply With Quote
Old 07-06-2007, 05:41 PM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Originally Posted by ranchmink
Good point,
Now days, you are required to recover R12 no matter where you live in the US. I converted my old 84 Audi to R134 a few years ago, and only changed the seals I disturbed in the process. My theory was that the old stuff had hardened already and were not as vulnerable as fresh o rings. This lasted the rest of the life of the Audi, another 3 years and worked fine. I did have to purchase a set of R134 gauges, though. My vote is ďDonít fix it if it ainít broke!Ē Just replace the clutch and enjoy the R12.
Vaughan
Old 06-28-2009, 03:11 PM   #5
Astrodokk's Avatar
Pertinant revival of 2 yr. old thread...
Apparently, the PO had the AC replaced with the newer stuff already. It never has worked well through the dash, so I hardly ever turned it on. The bearings never did fail, but now that I'm restoring her, they'll get done. It's very hot here in N. California today!
Old 06-28-2009, 08:06 PM   #6
ranchmink's Avatar
Ac
Now that I have had a season on the system, I am happy with the results. The only issue is with the size the RV you can only expect to the front seat area comfortable. We normally run the coach unit when we are traveling normally which puts out more cool air and sometime augment with the dash unit.
Chris Addington
Central California
Old 06-29-2009, 10:36 AM   #7
1989 34.5' Airstream 345
Silverton , Colorado
Shields UP!
We put a spring loaded curtain rod across the unit, just behind the front seats, and hung a clear shower curtain from it...the dash ac keeps the 'compartment' cool. It helps block off the front when we're stopped and running the roof ac. Come winter time it works as well for the heat. May not look elegant, but I choose comfort over aesthetics.
mike
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 06-29-2009, 01:34 PM   #8
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
We took the whole system out - reduces weight on the front end (which is overloaded in almost all Classics) and simplifies cooling airflow. When A/C is needed, start your generator and run the roof air(s).
just my $0.02.
-Jamie
jking is offline   Reply With Quote
Dash Repair Questions JW84345 Airstream Motorhome Forums 15 07-15-2012 08:59 PM
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Dash A/C PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 32 08-10-2003 04:39 PM
1982 dash alfalsetto Airstream Motorhome Forums 0 10-31-2002 09:32 PM
Dump Valve Rebuild wagsrp Waste Systems, Tanks & Totes 2 10-12-2002 01:01 PM
