Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 12-26-2009, 01:31 PM   #1
silverback's Avatar
2006 28' Safari SE
Colorado Springs , Colorado
New leak #2 81 Excella 280 TD
I have oil dripping from what I believe is the crankcase breather hose on the bottom left side (street side) of the 6bd1t turbo diesel. I never noticed it doing this before. It is not very much but I hate leaving spots in the road (at least in front of our house ). Any ideas on what causes this? It was sitting for a while and when it was run it was not really driven. The oil pressure did seem higher then the last time I had done any Interstate driving but I attributed that to the cooler weather. It was mid August in AZ on my previous drive. Cause for concern?
Ken
4CU Charter Member
silverback is offline   Reply With Quote
Old 12-26-2009, 02:06 PM   #2
Mike Leary's Avatar
1984 31' Airstream310
Ajo , Arizona
How many miles are on the engine? I'd be thinking turbo or hydraulic hose leaking, check your power steering fluid and oil.
Mike Leary is offline   Reply With Quote
Old 12-26-2009, 02:33 PM   #3
silverback's Avatar
2006 28' Safari SE
Mike,
Good question. I was just going over the previous owners maintenance records and I'm going to guess over 120K on this engine. Maybe a lot more. The speedo was replaced at ~138K miles. The original engine was replaced with a 6bd1t from Isuzu.
-Ken
4CU Charter Member
Old 12-26-2009, 02:37 PM   #4
Mike Leary's Avatar
Ajo , Arizona
You should not have blow by; check those other hoses and come out to Ajo for a visit.
Old 12-26-2009, 10:11 PM   #5
silverback's Avatar
2006 28' Safari SE
Everything checks out OK. The engine is an 89. Tag is stamped 9/89. We have been discussing coming down to Ajo for a visit. If we get everything sorted out it would be after the 4CU New Years rally at Picacho Peak.
4CU Charter Member
P30 swaybar bushings for 81 Excella 280 silverback Classic Motorhomes 12 09-16-2009 08:01 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
Mystery light on 1982 280 Excella Dash jisom12 Classic Motorhomes 9 09-14-2008 02:33 PM
Leak in 94 Excella bathroom ernesto ca Sinks, Showers & Toilets 1 08-11-2008 03:45 PM
Help 82 280 Brakes jjhypnotist Brakes & Brake Controllers 0 08-01-2007 09:55 PM
