Old 05-16-2018, 07:42 PM   #1
1987 34.5' Airstream 345
Menomonee Falls , Wisconsin
New front furnace won't even blow air
hey,
So I put my new suburban 30sp furnace in. Wired it per the intructions, got a 12 volt new thermostat. Pushed the lever to start it up. Nothing... Not even the fan comes on. LP is not hooked up yet. Is there a breaker n the 325 that powers the front furnace? Electrical stuff is not my strong point,..... Help me, said the fly. DJ
davejay is offline   Reply With Quote
Old 05-16-2018, 07:48 PM   #2
1986 31' Sovereign
Miami , Florida
A little confused by "12 volt thermostat" - the thermostat simply serves as a switch -- the operating 12vdc should be directly wired to the plug at the furnace...
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 05-16-2018, 07:57 PM   #3
Hey,
Well apparently we must use a 12 volt thermostat. The hardware store has very cool thermostats, but they are all 110 volt house stuff. Low voltage needed I guess.
Old 05-16-2018, 08:27 PM   #4
2007 22' International CCD
Yup. Most of them run on 24 volts AC power...
Old 05-16-2018, 09:52 PM   #5
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
You could have a funky thermostat. I experienced the same thing after installing a new furnace. Try bypassing the thermostat by just tying the two conductors together. This way you can at least take that component out of the picture.
Charly
streamquest is offline   Reply With Quote
Old 05-17-2018, 06:28 AM   #6
Hey,
I thought maybe I got a bad thermostat, but the directions specificity say, turn thermostat to the off position. These cheap ones don't have an off position. You move the lever all the way left, and the little reed switch goes to off. There must be a breaker for the furnaces. Anybody know.
Maybe an off position sends some sort of message to the board. Can't see how that is any differant than clicking a reed switch to open the connection. DJ
Old 05-17-2018, 12:11 PM   #7
Grosspoluter's Avatar
Franklin Park , Illinois
Originally Posted by davejay View Post
hey,
Is it possible with all the new safety features, maybe there’s a pressure safety switch that needs to sense pressure in the LP line?
Grosspoluter is offline   Reply With Quote
Old 05-17-2018, 01:40 PM   #8
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
So it sounds like you're not yet certain there's power to the furnace (you're speculating about breakers and such.) Do you have a multimeter or even a basic circuit tester? You should make sure power is present and connected at the right places before getting into more involved troubleshooting... sometimes it's the simplest stuff.
— David
Old 05-17-2018, 05:28 PM   #9
gr.austin's Avatar
2009 27' FB Classic
Sioux Falls , South Dakota
On my Classic the furnace is 12V. So the t'stat should also be 12V. Check to see if the t'stat is in the heat mode. Also check that the t'stat is wired to the correct terminals for heating. The t'stat wires should either go to a circuit board in the furnace or go to a relay in the furnace control box.
If you can send me a photo of the Furnace control circuit diagram I may be able to help you more. If you can send me a photo of the T'stat terminal strip (where wires hookup)that would also be a big help.
Happy streaming
gr.austin is offline   Reply With Quote
Old 05-17-2018, 06:54 PM   #10
Hey,
The new furnace has a connection with a red,to power, yellow to ground, two blues for the t stat. Pretty simple. I'll take my fluke to the t stat connections in the t stat. Should have 12 volts there. Other than that I'm lost. DJ
Old 05-19-2018, 11:09 AM   #11
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Tie the two blue wires together and test your furnace operation. That will bypass the stat.
mayco is offline   Reply With Quote
Old 05-19-2018, 11:39 AM   #12
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Some furnaces have a safety feature that once it is tripped it must be reset by cycling power to the furnace. My furnace has a rocker switch accessible from the outside.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 05-19-2018, 08:25 PM   #13
Thanks guys,
I think I'll take it out.....again... And see if there is an on/off switch buy the wires coming out of the case. It could be that simple. I flunked it, and I got 12 volts on the power lead. But no voltage on the stat wires. Tried jumping them, nothing. So there's were I'm at. Thinking of getting dinisour board right from the gitgo, to save me hassle later. Does the new 30 sp suburban have an external on off switch? Thanks DJ
Old 05-19-2018, 08:47 PM   #14
According to the schematic I found, one of the furnace leads should have 12V on it. It is supposed to be connected to the same terminal on the furnace as the 12V coming in to the furnace. The thermostat sends the 12V back to the furnace to cause it to operate. If you don't have 12V on one of the blue wires (according to the schematic I found) the furnace will not run.
That schematic does not show an ON/OFF switch. Another schematic shows a switch on the valve that is NC. It may be sensing gas pressure. You may have to have gas to get the furnace to run.
EDIT: I finally saw the model numbers in the fine print on the schematics. The 30SP appears to have a switch on the gas valve. I bet you need gas pressure to operate it. But it still looks like there should be 12V on one of the blue wires.
https://www.manualslib.com/manual/79...page=35#manual
Al
S/OS #004
Furnace won't blow hot with 12V lights on. sbroemer Furnaces, Heaters, Fireplaces & Air Conditioning 8 10-13-2014 08:51 AM
furnace won't blow hot 73argosy24 Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-13-2014 08:13 AM
Newer AS (2008) - correct air pressure to blow out water lines bonginator Winterizing, Storage, Carports & Covers 17 10-04-2012 08:47 AM
'71 Airstream A/C fan won't blow davespann General Repair Forum 1 06-25-2012 06:57 AM
My Furnace Won't Blow AirSpleen Furnaces, Heaters, Fireplaces & Air Conditioning 8 10-07-2006 08:04 PM
