Hello,
Find a company that has drop deck trailors better yet , a double drop deck . That way they can drive onto the trailors and your coach sits lower. A flat bed will not work your to tall. A drop deck will work, but ramps will be needed. You pay for that . The double drop deck , is for hauling excavators, bull dozers.the front of the trailors disconnects from the back. WAY Easy. Here's the issue. Many times a company has loads out, but not returns. I got a quote to haul our325 from Maryland to Milwaukee for 2000 if I was flexible as to when it could be moved my325 won't fit on a double drop. 28 feet is as long as you can get on a double drop. I have a company up here weidemeyer trucking out of Jackson,wi. They do all 48 states . I think the guy I talked to was justin. There's got to Bo flatbeders out of fl. Try California too a lot of times they'll give you a deal, just to get back to home base. You'll need height and width, weight, and will it move forward backward on its own . My unit went 1000 miles. 1800.oo. Hope thus helps.
