Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 11-05-2012, 10:11 AM   #1
Fairbanks , Alaska
Need some help --- wait - who doesn't??
Hi guys, well -- so long Alaska and welcome to Palm Desert! Hehe -- sunshine all day etc... Anyhow, I have a blown head gasket or perhaps an exhaust gasket on one of the cylinders - I have a 454 Chevy gas engine and I find it quite hard to find anyone to work on it or help.
Do you guys know anyone in the Palm Desert/Springs area that could help me out?? am even thinking of perhaps swapping my whole engine and/or fuel inject the thing while I am it.
Thanks for any help/suggestions.
Chris.
Also, I am looking to get back in touch with Artstream, Betty and Chris (they have a TT airstream pulled by a black Hummer) -- if anyone has their contact info...would be great. Thxs.
Liz and Chris -- Follow our Full Time Adventures on https://www.gypsymoments.com
Visit my new Airstream renovation blog here:
https://www.AirstreamLoft.com
gypsychris is offline   Reply With Quote
Old 11-05-2012, 11:38 AM   #2
ASwifey's Avatar
2018 30' Classic
Chris, I would suggest calling the local Bureau of Automotive Repair (BAR). They should have a list of reputable garages in that area.
Good luck.
Southern California Airstreamers Just ask to join!
I do yoga to relieve stress, just kidding I drink wine in yoga pants
ASwifey is offline   Reply With Quote
Old 11-05-2012, 02:19 PM   #3
Fairbanks , Alaska
Good luck.
Will do -- just hoping someone has experience with some people down here...
THANKS
Old 11-05-2012, 02:57 PM   #4
captdaddy's Avatar
1985 25' Sovereign
2005 30' Safari
1986 34.5' Airstream 345
COMFORT , Texas
You might try Bob Miller RV in the Banning area....very knowledgeable and reasonable....used them on my way from LA to Texas....may not do the work there but they'll know a good place to send you
Don
captdaddy is offline   Reply With Quote
Old 11-06-2012, 07:58 AM   #5
1989 34.5' Airstream 345
Silverton , Colorado
Hey Chris&Liz,
Been awhile...
You might try Good Sam...they have towed us and steered us to good mechanics.
Do you have water in the oil? We just replaced our R exhaust manifold and gasket...the weight of the exhaust system will pull on the manifold, and over the miles, will loosen the u-bolt(s) holding the pipes in place.
Could you PM me...? I can't access our blog(been over a year)...mike&tracy
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 11-06-2012, 12:01 PM   #6
crazeevw's Avatar
Saint Petersburg , Florida
Chris,
Do you have the cast-iron exhaust manifolds or headers? Cast Iron headers on the 454 are known for blowing gaskets. Something to check on.
Any luck on a good mechanic yet?
Good Luck, Derek
Old 11-06-2012, 02:35 PM   #7
T thought our exhaust manifold was cast iron, but it was stainless...
Artstream emailed me from the west around mid-October...sounds like he's doing better...
The SS Ex Man was cracked/broken, and a fellow in Tucson welded it back together, welded a patch over the weid, and it was about $150 cheaper than the replacement would have cost...it must have been cracked when we bought it, as I had to keep checking the tach to make sure the motor was running...VERY quiet...he recommended having flow inhibitors installed in the exhaust ports to help it run cooler.
Michael & Tracy
1989 345 Motorhome
Old 11-06-2012, 06:44 PM   #8
Hi Chris,
Any sign of overheating or blowing coolant out?
Sent you a PM... if I can help!
Old 11-08-2012, 11:28 AM   #9
Fairbanks , Alaska
AM in coachella now.... still looking and I have to be on the road tomorrow... what a headache!
Old 11-12-2012, 11:17 AM   #10
Fairbanks , Alaska
Thanks to Keyair, we replaced manifold and other stuff.. seems to be running pretty well -- I am at a loss cos my ignition wires (spark-plug wires) keep baking on me -- yes they keep frying right where they meet the plugs -- any ideas??
Old 11-18-2012, 07:43 AM   #11
crazeevw's Avatar
Chris, fried spark plug boots are common with cast-iron exhaust manifold. Recommend investing in tubular headers
Good luck, Derek
Old 11-18-2012, 03:25 PM   #12
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
There are lots of ultra high temperature insulating products available to deal with similar problems. Most of them have to do with car and motorcycle racing applications. Google "ceramic exhaust insulation" and you will come across a bunch of them. I know that there are tube shaped "sleeve" materials available that are designed specifically to protect wires. If you had tubular headers, I would suggest wrapping them individually before installation, but I'm not so sure that would work with stock exhaust manifolds.
Charly
streamquest is offline   Reply With Quote
Old 11-18-2012, 04:44 PM   #13
Asbestos matting(I know, I know) would work well...
Michael & Tracy
1989 345 Motorhome
Old 11-18-2012, 07:50 PM   #14
crazeevw's Avatar
Chris, try the high temp wraps that Charly is recommending before investing in tubular headers. A much more inexpensive 'fix'.
Good Luck, Derek
