Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 04-28-2008, 12:55 PM   #1
Profile:  Plantersville , Texas
need a new compressor
I replaced the front air bags and put new front and back shocks on my 83 classic MH. In trouble shooting the rear air bags, I checked the compressor and discovered that altho it is running all the time it isn't putting out any air. A fellow air forums member suggested a thomas compressor from ebay. I found the one on the link below and am not sure if it will be big enough. I may have to replace the bags and maybe the tank. I can't troubleshoot any more until I get air pressure.
Any suggestions on a compressor and a ballpark price for me to expect to pay would be a great help. I have done a search on internet and only seem to be able to locate the type that plug into a cigarette lighter. I called Inland and the lady told me that they didn't carry them. I need a source to purchase if anyone can help.
My MH is a lot higher in front now that I have the new shocks and airbags done. She looks ready to leap with her back all crouched down. Gotta get her level.
Thanks Kay
12V DC AIR COMPRESSOR 12VDC THOMAS 215 - eBay (item 160233493707 end time Apr-30-08 12:06:17 PDT)
carnegie1935 is offline   Reply With Quote
Old 04-28-2008, 03:34 PM   #2
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 73
Airstream motorhome owners appear to be in the minority here
Airstream motorhome owner, and forum member swebster, hosts this site.
If you do not get a good answer here, try posting your question there.
Tom
Old 04-28-2008, 05:39 PM   #3
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Firestone makes a complete line of 12VDC compressors that they use for their suspension-assisting air bag products. You might check them out, or google 'Ride-rite'. You can also look into another suspension company called 'Airlift'.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 04-29-2008, 03:57 PM   #4
Profile:  Norfolk , Virginia
Kay,
I got my compressor from Summitracing.com.
Steve
Geophilist is offline   Reply With Quote
Old 04-29-2008, 07:27 PM   #5
Thanks for all the information. I have found a source to purchase a pump. They are pretty high dollar. Today we plugged the line from the compressor and put air into the tank with the bottom valve. The bags aired up and so far we have found no leaks. We put 90# in tonight and will check in AM to see how they held. Can I continue to air them this way and not replace the pump at this time. I can check that air when I check my tires. Kay
Old 04-30-2008, 07:05 AM   #6
Profile:  Jefferson , Arkansas
Kay,
Yes you can run that way for a while. Depending on how rough the road is you're driving on and how many times the load leveling valve has to dump air to drop the height of the coach. Each time it dumps air the next time it has to put air back into the bags your reservoir drops in pressure. Eventually the rear of your coach will drop to the point where the load leveling valve stays open calling for air and then your tank will be emptied.
This is what happened to us when we first bought our motorhome and were driving it home the first time. You'll know when you're out of air because the ride will get REAL rough and the rear suspension will start banging on the frame.
If it was me I would drive as slow as possible and get the compressor fixed asap.
We bought a compressor like Guy99 uses. He seems to have had good success with it so far. We paid $60 at Harbor Freight for it. If you'd like more information on it let me now and I'll dig it up.
"Wherever you go... there you are." - Buckaroo Banzai
1984 310 Limited Motorhome
1974 31' Excella 500 (future hauler for 2 Triumph race cars)
1974 20' Argosy Motorhome (future Excella 500 tow vehicle)
Old 04-30-2008, 09:43 AM   #7
Thanks Brad,
I understand the concept , but not all the details. You made it clear why I need a compressor. Yes i would like a part # . I can handle that price. we have a HF store nearby or I can order online. My bags were empty this AM so I will look for my leak later today. I hope it is ony a fitting or line.
Kay
Old 04-30-2008, 11:51 AM   #8
Kay,
Check the schrader valve where you added the air. They often "crud up" and when you open the valve, the crud keeps the valve open. Get a new one from an auto parts store and the tool to remove them. Also, the tanks like to get pin holes in them from rusting from the inside out.
Good luck on your hunt.
Steve
Old 04-30-2008, 01:18 PM   #9
Originally Posted by carnegie1935
Thanks Brad,
Kay
Kay,
Here is the link Harbor Freight Tools - Quality Tools at the Lowest Prices to the compressor we bought. Its the same one used by Guy99. I haven't had time to install it yet, possibly sometime this summer. The compressor in our motorhome still runs but takes a LONG time to fill up the tank. We bought the Harbor Freight unit figuring ours wouldn't last much longer and the price is reasonable.
Hope this helps.
Old 04-30-2008, 02:27 PM   #10
Thanks Brad,
I ordered this online today. I hope it will do the job.
Kay
Old 04-30-2008, 04:29 PM   #11
Thanks Brad,
Kay
I have high hopes for it. It seems to have served Guy99 well which is why I felt it was worth trying myself.
Old 05-01-2008, 08:53 AM   #12
guy99's Avatar
Profile:  Dunsmuir , California
Images: 16
Just to clarify, (and to give credit where credit is due) it is pwhittle, not I, who is using this compressor for his rear suspension. Apparently bkahler also is having good luck with the Harbor Freight unit.
I do have one of these compressors which I carry for emergency tire inflation, etc. Seems to do that job fine but it does blow a fuse if I try to start it while it is connected to my MH tires.
Here's the thread where pwhittle describes the installation of this compressor.
Compressor ideas needed .... Help!
guy99 is offline   Reply With Quote
Old 05-01-2008, 09:48 AM   #13
Guy, sorry for falesly attributing its use to you! I knew you had one and remember the thread where someone said they were using it as their suspension compressor.
Looking at PWhittle's latest post in that thread (Janurary) he states its still working fine.
Kay, I appologize if I misled you as to who was using the compressor in their coach. I knew someone was, I just thought it was Guy.
Sorry about that.
Old 05-01-2008, 11:18 AM   #14
guy99's Avatar
Images: 16
Sorry about that.
No apology needed, I just felt guilty getting credit for a good idea which wasn't mine.
Guy
Pingbacks are On
new compressor norbert General Repair Forum 2 04-02-2008 09:47 PM
A/C Compressor question PhilMateo Furnaces, Heaters, Fireplaces & Air Conditioning 1 05-19-2006 07:23 AM
air compressor wanderingeye Towing, Tow Vehicles & Hitches 3 01-27-2006 07:47 AM
Compressor recommendation? rfield54 Fresh Water Systems 11 07-14-2005 09:02 AM
Air compressor ALANSD Airstream Motorhome Forums 15 01-02-2004 04:18 PM
SEO by vBSEO 3.1.0
