Old 03-06-2008, 05:42 AM   #1
Fairbanks , Alaska
Need help with my 345LE Engine!
Hi All! We just picked up our first Airstream -- a 1989 350LE! We are very excited, but there is one little problem. The engine starts fine, but when we start accellerating it chokes and stalls. Yesterday this went on for about an hour (we are in the process of driving her home to CT -- and had her in the right lane with hazards flashing), and then suddenly everything was fine -- she drove like a dream for 200 miles. Any thoughts on what the problem might be or how we can fix it? Thanks so much!
gypsychris is offline   Reply With Quote
Old 03-06-2008, 05:47 AM   #2
Fairbanks , Alaska
wanted to add: We have a 454 Chevy Gas engine. Thxs!
Old 03-06-2008, 05:51 AM   #3
87MH's Avatar
1978 31' Sovereign
Images: 292
See this thread -
http://www.airforums.com/forums/f159...ump-13792.html
On some units the wiring to the fuel pump is fed through an oil pressure switch, so, if the engine is NOT running, no voltage will be evident at the fuel pump (the switch is (oil) pressure activated).
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 03-06-2008, 06:51 AM   #4
swinginping's Avatar
1989 34.5' Airstream 345
waynesboro , Virginia
Is it still running fine? Maybe something got clogged in the fuel filters?? or in the previous post fuel pump?? but seems like some type of fuel or lack of fuel issue.
swinginping is offline   Reply With Quote
Old 03-06-2008, 06:55 AM   #5
87MH's Avatar
1978 31' Sovereign
Images: 292
Some interesting questions/solutions are here:
http://www.airforums.com/forums/f159...ade-16849.html
and a few more here:
http://www.airforums.com/forums/f311...ule-27047.html
and here:
http://www.airforums.com/forums/f159...ne-up-413.html
and even more here:
http://www.airforums.com/forums/f159...lls-10336.html
As with all things old, the probable cause of your problem is most likely from multiple system malfunctions, keep at it, repair/replace the old stuff, and eventually you will have a dependable ride. The best thing about self-repair is that you will be able to recognize and repair future failures in short order, either on the road or at your home base.
Dennis
WBCCI # 1113
AirForums #1737
Old 03-06-2008, 07:05 AM   #6
87MH's Avatar
1978 31' Sovereign
Images: 292
190, 290, 325, 345, 350, or 370???
Just wondering - I did not think that AS made a 350 in '89 - just the 190, 290, 325, 345, and 370.
If you have the 370, you are in an entirely different environment than the rest of the models. The 370 was set on a Gillig chassis with a Ford drivetrain - I have a friend who purchased one of these new and has a multistate horror story of a long line of breakdowns.
There is MUCH more info here on the Chevy 454 than the Ford 460 drivetrain.
Dennis
WBCCI # 1113
AirForums #1737
Old 03-06-2008, 07:45 AM   #7
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
Put some "Heet" in the fuel tank. Sounds like water in the fuel.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 03-06-2008, 10:00 AM   #8
Fairbanks , Alaska
we are now at a mechanic...on the road..somewhere in Ohio...as far as the mechanic can tell...its the fuel pump..(it was not even turning on!...) so I dont know....what it all is....I appreciate yall input and feedback...I will let you know how it goes...!!! BTW any ideas where are all the fuel filters in our 345 ? we have the one with the East-West queen bed...thanks again! 1
Old 03-06-2008, 01:36 PM   #9
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
There should be an inlet filter at the carberator/Fuel injection unit. There is also a canister type in-line filter located on the inboard side of the curb side frame rail just ahead of the cabin step.
Our 345 does not have the rear electric fuel pump. If your 350 has the rear pump, there is also a filter near it.
There is also an in-line filter for the Generator. (In the Gen bay)
Hope this helps, and welcome to the group!
Driving an Airstream Motorhome is the only way to go!
Rob
Robfike is offline   Reply With Quote
Update from us, our 345LE is for sale... williamhenshall General Motorhome Topics 5 04-27-2003 06:46 AM
Interior re-do of 1989 345LE charles white Airstream Motorhome Forums 9 03-21-2003 04:14 PM
water in fuel(345le) will Mechanics Corner - Engines, Transmission & More... 9 10-16-2002 12:38 PM
