Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 03-23-2012, 03:22 PM   #1
dadstoy's Avatar
_ , _
Shop is looking for part number for replacement rear brake hoses ( all three) before parts houses close today. Anyone have their's replaced recently? I have disc brakes on the rear.
Thanks!
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
dadstoy is offline   Reply With Quote
Old 03-23-2012, 03:29 PM   #2
"Cloudsplitter"
Thanks!
Flex hose?
Do what I did with my brake shoes yesterday...take off and match-up.
Old 03-23-2012, 04:03 PM   #3
dadstoy's Avatar
_ , _
Yes the flex hoses. They have matched up the fronts but are having a bit of a problem matching up the rears will local parts houses. The OEM number has changed twice and doesn't match up with current numbers.
Old 03-23-2012, 05:09 PM   #4
"Cloudsplitter"
Thumbs up
Yeah..yesterday I called ahead to make sure they had the brake shoes, but being familiar with parts departments I still took the originals with me.
Good thing 'cuz the difference between what they thought and what was needed turned out to be so small that it would probably have gone un-noticed 'til well into the job>
Doing full monte on my '58 Traveler Chlyman 1958 Traveler 77 06-13-2013 07:36 PM
Dexter brake shoes....a problem. ROBERT CROSS Brakes & Brake Controllers 34 07-04-2012 10:51 AM
02/12: New Tire Discussion on Woodalls: LT versus ST and more. slowmover Tires 128 04-10-2012 05:09 PM
Where is the check valve located on the rear airbags? Mr. D Mechanics Corner - Engines, Transmission & More... 5 03-26-2012 09:41 AM
Should I worry about rust on my hitch? loislane Hitches, Couplers & Balls 28 03-25-2012 12:54 PM
