Old 08-19-2016, 07:33 PM   #1
RBonney's Avatar
1983 27' Excella
1990 34.5' Airstream 345
Spring Lake , Michigan
Need brake HELP 345 LE 1990
I just did calipers, rubber lines and new master cylinder. It's all bleed and ready to tryout. Plus our week vacation starts tomorrow. Hopefully the Road Runner is ready. I notice now my back wheels spin while in jack stands. Why isn't it in park? Do I need to bleed something else or is it ready to fire up and test new brakes. Thanks.
RBonney is offline   Reply With Quote
Old 08-20-2016, 12:32 AM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Your park locks the driveshaft. With both wheels in the air they turn through the differential. If you turn one wheel the other side will turn in the opposite direction. Both wheels need to be on the ground to lock things up.
Cheers, Dan
~ Margaret Thatcher ~
Old 08-27-2016, 07:18 AM   #3
Menomonee Falls , Wisconsin
Hey,
Are you referring to your rear duals or the tag axle. If it's the tag, that's like a trailors Axle. They only will be locked when you put on the brakes, provided there wired . You'll see the 2 wires coming out of the backplate. Should be hooked to wires going to it from chassis. Now if you mean your duals the drives are spinning on the jack stands, that's a little strange. If your in park. Wheels will move a little ,back and forth maybe ane inch or two. But the driveline should be locked from the trans back. Is yours a diesel. If so, does it have an air buttom e brake. It'll be yellow or red. Pull to set brakes. If you got a gas engine, you should be locked when you put it in park. Is your 370 a ford 460 or 454 chevy. Either way the trans in park sets the driveline to a locked position. Put it in park, on concrete, on a Little hill. Let off the brake, if she rolls forward ,and keeps rolling, the parking lock in the trans is broken, or your linkage to the shift lever may be a tiny bit out of adjustment. It could be that simple your right in between park and reverse. Hope this helps
Dave
davejay is offline   Reply With Quote
Old 08-27-2016, 10:23 AM   #4
1986 34.5' Airstream 345
Alliance , Ohio
I think Smartstream has it right. The driveshaft should be locked but the rear wheels will rotate opposite each other thru the differential. I assume your parking brake is at the back end of your transmission and you have rear disc brakes. Rear drum brakes have the parking/emergency brake function built into each side rear drum.
mehes is offline   Reply With Quote
Old 08-30-2016, 04:31 PM   #5
RBonney's Avatar
1983 27' Excella
Thanks I'm going to check it out tonight.
Old 08-30-2016, 09:00 PM   #6
RBonney's Avatar
1983 27' Excella
Everything checked out fine on my test drive. Goes into park as it should. I do have one noise and I think it is the front right caliper rattling it goes away when I apply the brakes. Thanks again for the input.
1990 345 LE project Roadrunner RBonney Classic Motorhomes 12 08-21-2017 04:46 PM
1990 345 check valve 345bill Classic Motorhomes 4 01-09-2016 10:16 AM
1990 Airstream 345 - Texas ddannyd7 Airstream Classifieds 7 12-30-2013 08:30 PM
Need a Fuse Block diagram for a 1990 345 Tommoran Mechanics Corner - Engines, Transmission & More... 2 06-03-2013 08:59 AM
1990 345 Motor Home Rear Airbags Howard Lefkowitz Classic Motorhomes 5 05-11-2007 09:59 AM
