Old 05-08-2010, 03:26 PM   #1
Paul J Mauro's Avatar
1985 34.5' Airstream 345
Bolton , Massachusetts
need a new door lock for my 345
looking for a place to buya new or used 345 door lock assembly
no luck yet but anyone can email ideas through the forum or
lovemoney1@aol.com
Paul J Mauro is offline   Reply With Quote
Old 05-08-2010, 03:48 PM   #2
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Did you see my response in this thread? http://www.airforums.com/forums/f160...tml#post847032
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 05-08-2010, 04:05 PM   #3
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
That's a common failure, what exactly has broken? I did a c.s. repair on ours a few years ago that enabled us to put the vise grips back in the tool box.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 05-08-2010, 05:50 PM   #4
guy99's Avatar
Images: 16
Is there a thread where you describe your repair?
Here's what happened to mine:
http://www.airforums.com/forums/f453...ded-38558.html
Old 05-08-2010, 07:33 PM   #5
my housing fractured so the center shaft wobbles and its a bear to getthe door to close and latch with out about 10 tries .
Old 05-08-2010, 08:30 PM   #6
guy99's Avatar
Images: 16
Any possibility of getting it welded?
Old 05-08-2010, 09:09 PM   #7
Mike Leary's Avatar
Images: 11
It's a tacky fix, but JB weld with some hardware gussets will work. The handle below I should have put in years ago.
Old 05-14-2010, 09:01 PM   #8
going to try a welding fix on this plate before I go with the new lock.we will see how that goes.
Old 05-31-2010, 02:32 PM   #9
door lock fixed
Ok everyone thanks for the input and ideas -here are the pictures of the repair
drilled out the center made a new bushing and then made a plate to hold it solid
better than new and no too ugly
door lock 345
'86 345 Door lock Greg Reed Classic Motorhomes 8 05-08-2010 07:36 PM
Door Lock Robin Stone Doors & Locks 8 03-06-2008 04:27 PM
Door lock help juel All Argosy Trailers 6 12-28-2005 08:39 PM
Help with 345 door lock Greg Reed Classic Motorhomes 6 11-21-2005 10:13 AM
How to lock the door Dbraw On The Road... 17 05-18-2003 07:05 AM
