Join Airstream Forums Today
Old 09-04-2007, 08:13 AM   #1
jagcb750's Avatar
1986 30' Airstream 300
B , Louisiana
Mystery Switch
Allright, here's one for ya! I noticed that there is a little switch that is mounted in the bedroom of my 345 right behind the t.v. It appears to be one that has either two or three positions. left, in the middle, and to the right and you would use your thumb to press either left or right. The other day I noticed that it had popped out and was laying next to the t.v. There are two little contacts that are supposed to go inside of it. The plastic button must have popped out under pressure. If this is a factory switch, what is this switch for? I was wondering if it might have something to do with the heating system, because that is one system I haven't explored yet. I have, however, seen a regular thermostat on the wall in the bedroom. Anyway, what in the world is this mystery switch?
jagcb750 is offline   Reply With Quote
Old 09-04-2007, 08:28 AM   #2
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Dpdt
Is it only one switch?
Are they same type as row just inside door beside sink?
I have a pair in the bedroom,
One controls vanity lights
Other controls lights over bed.
klattu is offline   Reply With Quote
Old 09-04-2007, 08:35 AM   #3
jagcb750's Avatar
B , Louisiana
No, I have the two that controls the lights also. This switch is brown and is located above those behind the t.v. There is only one switch that moves to the left and right with your thumb.
Old 09-04-2007, 09:51 AM   #4
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
don't have a switch there
Have you found the switch for the emerson instant hot water heater? Took us a year to figure it out!
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 09-04-2007, 07:14 PM   #5
jagcb750's Avatar
B , Louisiana
@Str8strm: I am not sure. I got the little water heater thingy at the kitchen sink working if that is what you are talking about. I believe I just plugged it in though and it worked. There may have been a switch or something underneath the sink or something now that you mention it. There is a light switch in the kitchen and maybe one other switch there that I haven't figured out yet though!
Old 09-04-2007, 07:20 PM   #6
Liberator
klattu's Avatar
1972 Argosy 24
Images: 834
Maybe a antenna amp?
I had to go out and look at mine...
A 120v plug and a coax cable / cigar lighter plug is all I had back there.
Old 09-04-2007, 08:14 PM   #7
1986 34.5' Airstream 345
Tyler , Texas
Mystery switch
Hi! I have a 86 345 but do not have this bedroom switch....I do have a brown switch across from the 3 on the kitchen cabinets next to the entry door that I have not been able to find what it goes to. If you find yours help me with mine!
Pete
pjude is offline   Reply With Quote
Old 09-05-2007, 06:30 AM   #8
Chaplain Kent's Avatar
1994 30' Excella
Wauwatosa , Wisconsin
Pictures are worth one hundred words. Maybe an antenna switch.
Chaplain Kent
1994 30' Excella 1000, Chummy III- Ford Excursion- 7.3 Turbo-diesel www.milwaukeervrental.com
Chaplain Kent is offline   Reply With Quote
Old 09-05-2007, 07:37 AM   #9
str8strm's Avatar
ours is a vertical single "light" switch, located between the kitchen window and stove top on the wall---it is the top switch in our coach
AIR 7992
Old 09-05-2007, 11:20 AM   #10
Liberator
klattu's Avatar
1972 Argosy 24
Images: 834
Let There Be Light
It took me a few experiments to figure out what most of these do...
Still not sure about one by stove...
I hear a lady scream each time I flip it though.
Old 09-05-2007, 02:02 PM   #11
RivetAddict
swebster's Avatar
Louisville , Kentucky
mine looks (looked) like klattu's. Whatever you do don't turn on the flux capacitor above 88 mph.
Jag, sounds like something the PO added along the way. Maybe a speaker selector or something AV related.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 09-05-2007, 03:58 PM   #12
1984 31' Airstream310
Hmm, with that flux capacitor installed it kinda makes me wonder when and where your motorhome has been.....
Sure wish ours had one.....
"Wherever you go... there you are." - Buckaroo Banzai
1986 345 Motorhome
1984 310 Limited Motorhome
1974 31' Excella trailer
1974 20' Argosy Motorhome - race car trailer tow vehicle
Old 09-05-2007, 04:32 PM   #13
str8strm's Avatar
all right, we give..........
???what the heck is a flux capacitor? thats where our light switch is
AIR 7992
Old 09-05-2007, 04:47 PM   #14
azflycaster's Avatar
1975 25' Tradewind
Phoenix , Arizona
Images: 67
The flux capacitor
Is the devise that makes time travel possible.
Perhaps your 345(s) can not produce the 1.21 gigawatts of power to operate them or the 88MPH needed....
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Mystery Switch? saburkha All Argosy Trailers 7 08-22-2011 12:06 PM
Clipper, Dometic Refridgerator, Fridge Lamp Switch masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 8 07-15-2011 01:10 PM
univolt converter switch position? godaddy64 Electrical - Systems, Generators, Batteries & Solar 8 02-25-2011 12:17 PM
3 way switch just went kaput...replacing? MonaxLisa Lights - Interior & Exterior 24 01-20-2011 04:51 PM
Battery switch behind the sofa LawChick Batteries, Univolts, Converters & Inverters 9 01-13-2011 08:52 PM
