Old 01-30-2011, 01:42 PM   #43
Well, I got my head in inside the cupboard, and looked at the back of the switch.
Its 110V wires, so my gut feeling is that its as was suggested, the AC power switch for a 110V water heating element.
Either way, if I put a 110V element in, I will replace the switch with one with a warning lamp!
I just solved another Mystery switch puzzle!
This one:
Red switch on the wall, next to Refridgerator....
This one was a GEM....
I was trying to figure out what it was... had no idea... must have left it on, and next time I went over to work on it, the House batteries were dead...
I pulled the Fridge vent open and stuck my head in to see if I could see the back of the switch... traced the wires back down to this little fan!
So a cooling fan for condensor!
Old 01-30-2011, 04:02 PM   #44
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
Hmmm
I was just told this past week that these fridges are designed to not need a vent fan.
some one had placed a small fan in mine also. it was controlled by a temp sensor switch.
this A.S. Tech suggested these are the type of accessory's sold by vendors, sometimes at rally's, to Help ? maybe something that is not needed ???
John H. is offline   Reply With Quote
Old 01-30-2011, 04:57 PM   #45
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Originally Posted by John Haggard View Post
Hmmm
My B190 has one as well. In general they shouldn't need one. In the early B190s like mine there is no roof vent for the fridge, just two side vents, so the natural air flow isn't quite as smooth. In that situation the fan seems like a good idea.
Mine was hooked to a temperature sensor that only let the fan turn on when it was insanely hot. I bypassed it and run the fan on those really hot days when the air doesn't seem to be moving. Both the fridge and fan seem to do fine.
As for some of the other switches shown - my B190 has a switch that doesn't appear to do anything most of the time, but it does in fact turn off the lights on the bunk - the idea is that if you forget to turn them off, you don't have to climb up again to turn them off. (Unfortunately it also kills the lights above the couch...I guess in case you make the opposite mistake...) I suspect some of the switches in this thread may be something like that.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 01-30-2011, 06:11 PM   #46
Silverton , Colorado
I installed a computer fan just below the fridge vent with a lighted switch(when on) I mounted inside the street side access door...when the temp gets above 95, I go out and turn it on...it really does help...mike
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 01-30-2011, 07:04 PM   #47
and my trusty lab Helga
handyman1425's Avatar
1972 29' Ambassador
1985 32' Excella
Cowiche , Washington
That is why i like my trailer i can always get a faster vehicle to pull it.
handyman1425 is offline   Reply With Quote
Old 01-30-2011, 07:23 PM   #48
But does yer fridge work?
Michael & Tracy
1989 345 Motorhome
Old 02-01-2011, 04:35 PM   #49
Images: 13
Ha If not ? Drive Faster
Old 09-05-2011, 06:21 PM   #50
Drivers side behind the Sofa.
Clearly, its for the TV, but what is the switch for, the TV signal Amp?
Also, what is the multi-pin plug for top left side and the single pin bottom right side?
Better Pic.
Old 09-06-2011, 12:50 AM   #51
Liberator
klattu's Avatar
1972 Argosy 24
Heart of Dixie , Alabama
Images: 834
On mine...
Near sofa is the switch to lower sofa into a bed.
My TV is on the other side, away from sofa, and the amp is on same switch plate as the coax.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 10-07-2011, 09:50 PM   #52
Well, I figured out the Mystery switch in the bedroom...
Followed the wires into the underbed area..
Operates This small downlighter...
It seems someone needed a wee hours guide to the bathroom....
Old 10-08-2011, 03:24 PM   #53
glowing reccomendation...?
With that carpet, who needs a light? Nice carpet, by the way...beats the heck out of our once-beige rug.
Michael & Tracy
1989 345 Motorhome
Old 10-08-2011, 09:55 PM   #54
LOL, yes its HORRIBLE!
Guess what... I started pulling it up today... its SO ugly its not even fit to uses ate board padding for working on the roof!!!
Old 10-09-2011, 11:50 AM   #55
Actually, I was serious...well...as serious as I can be...I really DO like the carpet...m
Michael & Tracy
1989 345 Motorhome
Clipper, Dometic Refrigerator, Fridge Lamp Switch masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 10 01-05-2013 11:14 AM
Mystery Switch? saburkha All Argosy Trailers 7 08-22-2011 12:06 PM
univolt converter switch position? godaddy64 Electrical - Systems, Generators, Batteries & Solar 8 02-25-2011 12:17 PM
3 way switch just went kaput...replacing? MonaxLisa Lights - Interior & Exterior 24 01-20-2011 04:51 PM
Battery switch behind the sofa LawChick Batteries, Univolts, Converters & Inverters 9 01-13-2011 08:52 PM
