Old 09-12-2008, 06:21 PM   #1
1982 28' Airstream 280
Quitman , Texas
Mystery light on 1982 280 Excella Dash
Trying to figure out all of the workings of my 1982 280 Excella. On the dash there are 4 lights (leds).
one Blue - Bright lights
two green - left and right turn signal respectively
one red - ???
What does the red led indicate?
TIA
jisom12 is offline   Reply With Quote
Old 09-12-2008, 07:19 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Is it on when the step is deployed?
Is there a brake system warning light anywhere?
Does it go out when the engine starts?
Old 09-12-2008, 08:17 PM   #3
1983 30' Airstream 300
Plantersville , Texas
Red Light
I have a red light above my ignition key. It indicates that the ignition is on . i have a deisel engine that you have to pull the rod out to kill the motor.
Kay
carnegie1935 is offline   Reply With Quote
Old 09-12-2008, 10:14 PM   #4
Quitman , Texas
I know it isn't the step light.
From left to right the lights are:
Green Blue Red Green
I thought the Red indicator might be an alternator warning light. I haven't noticed it illuminated before. However, yesterday it came on and now stays on anytime the engine is started. I pulled the alternator and had it tested. It is good.
Old 09-13-2008, 05:49 AM   #5
Groveland , Massachusetts
It should be the door interlock, on when the door is open/unlocked. off when closed/locked.
classic310 is offline   Reply With Quote
Old 09-13-2008, 09:09 PM   #6
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
How do the brakes feel???
The red light on the dash in mine (same dash as yours) is for a failure in one side of the braking system. You may have a leaking master or wheel cylinder that is causing the proportioning valve to feed more fluid to one circuit. if that is the case you will get the red light. Check the brakes.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 09-13-2008, 09:37 PM   #7
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
huh?
Red is brake fluid.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 09-14-2008, 05:59 AM   #8
Well Preserved
1993 21' Sovereign
Originally Posted by Mike Leary View Post
Red is brake fluid.
Right. Red means stop.
Of course, depends on what the engineers considered important enough to get you to stop, but it is meant to get you to stop and check something, such as:
Brake system
Oil pressure
Alternator
Water Temperature
A door open
Old 09-14-2008, 07:28 AM   #9
Sorry to have given you the wrong info on the red light. My wife reminded me it was the emergency brake light. We use the emergency brake light when we park it on inclines. The light comes on when you apply it. On our 82 310 the only warning devices we have on the dash are all gauges.
Old 09-14-2008, 02:33 PM   #10
Norfolk , Virginia
JISOM 12,
Thenewkid64 is right on the money, it is the brake warning light. Do take care of this problem pronto. I can attest it is not a good feeling when the MOHO does not want to stop.
Steve
Geophilist is offline   Reply With Quote
Found a 1982 TurboDiesel 280 for sale metch Member Introductions 6 02-05-2013 07:49 AM
1982 280 Fuel tank Leaks. How to Drop it? k_rasmussen Mechanics Corner - Engines, Transmission & More... 6 05-15-2008 08:45 PM
1982 280 Leaks when it Rains k_rasmussen Classic Motorhomes 10 11-24-2006 07:04 PM
New Member, 1982 280 k_rasmussen Member Introductions 4 10-30-2006 08:52 PM
1982 dash alfalsetto Airstream Motorhome Forums 0 10-31-2002 09:32 PM
