Old 02-11-2018, 08:57 PM   #1
Huntington Beach , California
My crazy 310 Diesel Restoration - Many questions
Hello,
I purchased the Diesel Swap from Portland. It is in an awful condition. I drove it down to California and now I want to restore it properly. I need to redo the entire steering/suspension/braking stuff entirely.
First Question: are there any complete lists what I have to order? Mood parts or OEM? What is better?
Second question:
I want to work from up, not from down. What happens if I drill the rivets out to remove these parts? How is the windshield installed? I want to remove the blue lined parts.. any advice?
Best regards
Clemens
clemensk is offline   Reply With Quote
Old 02-12-2018, 03:55 AM   #2
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Welcome to the asylum Clemensk, glad to have you join us.
At the age of our classics most mechanical systems and rv appliances are due for overhaul or replacement. It's good that you made it home with your new rig.
Not sure what mood parts are, but it is nice that napa and most other parts suppliers have or can quickly get most parts needed for the chassis related repairs. With some notable exceptions, radiators come to mind. Recoreing is an answer in that case.
There is quite a welded in frame work under the skin in the cab sections that would still be in the way of doing engine work. As well as an amazing tangle of wiring and other components under the dash and in the forward under hood area.
Engine access is gained thru the front by removing the grill, hood and the radiator. Or thru the doghouse. The inner wheel wells can be removed for access to the sides of the engine. Not sure you would gain much by removing the skins.
Others here may add to this idea.
Searching here may turn up former post on areas or systems that you are digging into, or asking for specific details will bring support from those that have allready been there and can help.
Looks like you found a nice rig, the diesel being a plus. And are on the right track in getting it roadworthy. And fun/safe to use.
They are well worth the efforts once you are out there cruising and camping.
Cheers Richard
tevake is offline   Reply With Quote
Old 02-12-2018, 06:40 AM   #3
1987 34.5' Airstream 345
northern IL , Illinois
Hello Clemens
I just did a lot of work to the front end on my 345. Replaced brake lines MC, front coil springs everything on the front of the engine. Fun no but needed to be done. Pulling the skin off is not going to give you much extra what will you do with the floor may as well pull the whole body off omg.
Rock auto has good pricing on some of the parts you need.
And has moog parts.
What diesel is in your MO?
It was a gasser.
Your front end looks low to the ground.
Enjoy your new ride.
Hans 34.5 is offline   Reply With Quote
Old 02-12-2018, 02:09 PM   #4
Hey Hans 34.5,
I have to remove the skin to dent the front part out, and I have to check how the floor situation is, but for sure the entire floor in the back area will be replaced, it is rotted and not strong anymore. It is a 7.3IDI Diesel with a E4OD. Both are strong except that the new starter doesn't disengage always, will have to check this. I will check rock auto. The picture was taken before the front airbags went in, now the ground clearance is higher. But I think I need to put a little bit stronger springs in it to compensate the weight of the new engine. I will start to gut it out this weekend and then I will see.
Old 02-12-2018, 02:28 PM   #5
If you try to remove the outer skin as you're suggesting you won't gain anything by doing so. Once the outer skin is off there is the inner skin you would have to deal with. And then there is the insulation between the walls, etc.
Having dismantled and scrapped a 345 it's my belief that the only way to work on these is the way everyone has been doing it for years which is basically laying under neath or reaching in from the front or laying on top of the engine. Richard gave some good advice on how to access things from the front.
As for the dent you have to deal with you can try a suction cup or something similar. Since the skin is made of aluminum once a dent is present the skin gets stretched and there's no real way that I know of to shrink it back to size. The particular section of skin you're looking at is formed over a die and unfortunately is no longer available from Airstream. The best option would be to leave it as is.
Old 02-12-2018, 03:11 PM   #6
1969 31' Sovereign
1982 28' Airstream 280
Edmonton , Alberta
for aftermarket parts including front springs. supersteer is a great company to get some front end parts from definitely the best quality out there.
Swillv8 is offline   Reply With Quote
Old 02-13-2018, 07:07 AM   #7
Welcome!
Where in CA are you?
Seem to remember seeing a 7.3 diesel powered MH in the NW posted on the For Sale thread...
if so, thatís a new one and I/we need to know all about it!
I will also have to add it to the Diesel swap thread!
I think he meant MOOG parts. Smell check sucks....
Normally better quality ball joints etc.
Pictures of the dent and engine please!!!!!
Keyair is online now   Reply With Quote
Old 02-20-2018, 11:43 AM   #8
Hello again,
so this weekend I gutted her out. Nothing left inside anymore. It was around 800kg what I brought to the landfill. If anyone wants the microwave, the propane cooker or the 6.5kw genset - it is available now.
The engine is a 7.3IDI with an Allison 545 transmission. This is a confusing combination. If someone has data, I would be interested in the weight of the original configuration. (7.4l, 454 and th475??) I need to calculate the additional weight to know how much is left for the interior and how to deal with the springs. Btw, does anyone ever went with an empty factory 310 on a scale? Is the advertised weight correct?
And has anyone a source for the windshield and an manual how to get the old ones out?
Best regards
clemens
ID:	304597   Click image for larger version
ID:	304599   Click image for larger version
Old 02-20-2018, 11:48 AM   #9
Nice Work...
Info says the engine is about 900lb or 410 KG... so thats probably 2-300lb more than the 454...
Engine info...
https://en.wikipedia.org/wiki/Intern..._Harvester_IDI
http://www.dieselhub.com/idi/7.3-idi.html
http://www.intellidog.com/dieselmann/idi.htm
http://www.trucktrend.com/features/1...iesel-engines/
Old 02-20-2018, 12:56 PM   #10
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Screens are available from Coach Glass (https://www.coachglass.com/), supplied to them by RV Glass (http://www.rvglassexperts.com/rv_windshields.html) (both companies owned by same guy, but only Coach Glass have a retail arm). Make sure you order with the correct tint (along the top edge) to match the existing ones.
To remove/re-install you remove the locking bead, easiest done using a locking tool like this
The screens run at about $750 plus tax and shipping (which can double the price) so seriously consider having one installed by one of the nationwide glass replacement companies as they may already have supply agreements in place to cover things like shipping.
martin300662 is online now   Reply With Quote
Old 02-20-2018, 01:03 PM   #11
1969 31' Sovereign
Edmonton , Alberta
This is from November 7th, post from me on anther thread. Not sur if you are able to drive to Oregon but here are the prices.
Okay excellent news!!!!!
I called rv glass solutions and confirmed a 81 argosy/ airstream windscreen is
$544 per side
$336 gasket
$60 urethane kit
$650 labour
$2134 total.
This is obviously today's price, price can change etc etc.
I made the mistake initially calling mine a classic? Only thing that came up in their system was a 1990??( I thought this was the same size as 82?) or is it wide body?
Well I'm recording the price here anyways. 41" high. 53"wide.
$427 per side other costs are the same
The lady I spoke to gave me a bit of detail. They make the glass, they supply coach. It is thicker and stronger than guardian brand( original). Also cross strength, radius, something for how it's made is better. Only colour they offer is blue tint. They need 1.5 days to install(. 1/2 install, 24 hr cure). If you go to coburg, Oregon obviously no shipping. On the website they list Arizona and Florida as other warehouses so check into it as a drive to one of these locations can save you money
As for myself cheapest quote I could find locally was $4750cad. In Oregon its$2750cad. It's a 1100 mile one way trip. I'm going to try to do this next year make a mini vacation out of it. I'll probably spent the $5g still but some of that will be bonding time with my girl and a couple good friends with good food and drinks in Oregon
Old 02-21-2018, 10:20 AM   #12
What's next.
I see in the bedroom it looks like you pulled some of the covering off the aluminum. Is that what I'm seeing. The shiny panel.
Old 02-21-2018, 04:11 PM   #13
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
I don't know how many times I've told people....keep everything until your renovation is complete, as you never know what little part you need, or panel to use as a template.
I say this with all hope and prayers....Goodluck with your project.
Cheers
Sidekick Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 02-21-2018, 05:58 PM   #14
Cheers
Sidekick Tony
If nothing else the original parts are good for patterns. I only toss an original part after I'm sure I've installed some sort of replacement. What that really means is I've still got a lot of old sh!t laying around
1982 turbo diesel 310 :: 2013 Airstream turbo diesel 310 mayco Airstream Registry Discussions 1 07-28-2015 11:58 AM
How many miles are too many??? crabbey1 Tow Vehicles 26 03-29-2014 07:34 PM
1973 Airstream Land Yacht Sovereign -- Many Many Many Upgrades!!! eBay Watch Airstreams on eBay 0 06-18-2013 06:30 PM
OT: How many trailers is too many? Amazing short video. SilvrSausage On The Road... 1 09-10-2008 04:44 PM
