Old 09-23-2016, 05:24 AM   #57
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
I have already committed to upgrading to 98 amps from my previous 78 amp alternator. It should be repaired and upgraded either today or latest Monday. I hope 98 amps will be sufficient and not get a voltage drop when turning on all of the exterior lights.
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
Old 09-23-2016, 05:43 AM   #58
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Gunner, have you converted any of your exterior lights to LEDs? That will help some on the load side. Ive done all my running lights but nothing to my head lights or tail lights. Even when pulling the light switch out to the first position, without headlights, there is a good bit of amp draw on that circuit. One of these days Ill do my headlight conversion.
mayco is offline   Reply With Quote
Old 09-23-2016, 09:39 AM   #59
Gunter
gunner's Avatar
Greenville , Ohio
I have changed to LED the top running lights and back up lights. I have not done the turn signal, tail lights or the head lights.
Gunter
Old 09-23-2016, 04:49 PM   #60
I couldn't find the Lestek alternator in my shop. It could be in the barn and I'll try and look for it sometime this weekend. I may also have some pictures that I took of it and will search for those as well.
Old 09-24-2016, 08:27 AM   #61
Gunter
gunner's Avatar
Greenville , Ohio
Don't spend your time looking for it. I will live with the 98 amp alternator. It would have been interesting to know what amperage Airstream did install originally.
Gunter
Old 09-24-2016, 10:24 AM   #62
mayco's Avatar
The book on my 310 TD says it came with a 50amp alt. Though the numbers on the alt, which I think is oroginal, indicate an 80amp. Probably different than the gasser, or could be due to lack of demand on the alt.
Old 09-24-2016, 10:55 AM   #63
Well, my memory failed me on the amperage output for the Lestek. It 's 105 amps. I must have been thinking of the CS144 alternator I'm putting in my Argosy.
ID:	272262Click image for larger version
ID:	272263Click image for larger version
The alternator I took out of Peanut was a 94 amp unit and I replaced it with the the same size. Apparently Airstream (or GM?) offered an upgrade from the the standard 63 amp to the 84 amp unit.
Old 09-25-2016, 07:31 AM   #64
Gunter
gunner's Avatar
Greenville , Ohio
That just confirms my repaired 98 amp unit will be fine, can't wait to get it back and test it with all my external lights on and hope it stays at 14 volts.
Gunter
Old 09-25-2016, 08:33 AM   #65
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Doubt it will unless you replace all the wiring and contact points. Corrosion causes voltage drops too.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 10-07-2016, 03:48 PM   #66
Roquefort's Avatar
1975 29' Ambassador
1986 34.5' Airstream 345
Grefrath/ Germany , NRW
Hey,
the "german guy" had also some "little issues" with the alternator last trip (see "the adventures of Bangles in Europe").
Our voltage was very weak, exspecially at night. 11.5 to 12.2 Volts max.! very bad at idle speed at daytime as well.
The lestek unit was unreplacable in Germany....!
I just cleaned the corroded contacts, sprayed with WD40 and replaced the corroded screw (just one was there!!!) and added one. The ground is only taken from the radiator housing, the regulator (LESTEK as well) is on top/passenger side. I added a heavy ground wire from this radiator frame to the chassis and the "issue" was solved.
13.7 Volts imediately, dirctly after idle speed. full throttle, same power.
A quick and "cheap" fix!Click image for larger version
Name:	ImageUploadedByAirstream Forums1475876891.952670.jpg
Sent from my iPhone using Airstream Forums!
Roquefort is offline   Reply With Quote
Old 10-13-2016, 09:19 PM   #67
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Am I seeing this right? It looks like the Lestek is a self-exciting, internal regulated alternator with a field and sense terminal. Identical to the GM version save the orientation of the blades for the pigtail. This means you could replace it with a GM AC Delco 10SI and splice in the GM Pigtail in place of the Lestek, or upgrade to a 15SI if you need more power.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 10-14-2016, 04:17 PM   #68
Roquefort's Avatar
1975 29' Ambassador
....oops! This is FAR too spezialized for me.
All i can say, LESTEK is out of business, you can browse Google, then you'll find quick some other solutions. I have -elsewhere- filed a wiring diagramm for a replacement regulator, allow me a few days to find it.
Before you spent time and money to replace the LESTEK regulator, try to clean the contacts and i proove the "ground" of it. I did so twice, it worked well!!
Hopefully you will "make it", good luck!
Old 10-14-2016, 06:55 PM   #69
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I have had a Les-Tek alternator on my Snap-On truck since 1989....totally re-buildable and totally reliable. Regards, Bob
bobmiller1 is offline   Reply With Quote
« Step motor | Top | Air bags »
Freaking out shaggy1970AS Water Heaters, Filters & Pumps 7 07-09-2014 11:20 PM
Air conditioner works, but not cool starflyte1 Furnaces, Heaters, Fireplaces & Air Conditioning 50 09-25-2010 12:20 AM
Freaking out augier Repairing/Replacing Floor &/or Frame 54 04-11-2009 04:03 PM
carrier v low cool vs high cool rvlover Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-06-2008 08:20 PM
