Old 06-11-2016, 07:35 AM   #1
rmuller's Avatar
Madison , Ohio
My 87 345 Adventure
Today is the day! Going to pick up this beauty in Michigan. We just put 8 new tires on checked the fluids and will be attempting the drive back to Cleveland (364 miles). Wish us luck and I will post pictures from the trip.Click image for larger version
Name:	ImageUploadedByAirstream Forums1465648545.475122.jpg
rmuller is offline   Reply With Quote
Old 06-11-2016, 07:47 AM   #2
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally Posted by rmuller View Post
Today is the day! Going to pick up this beauty in Michigan. We just put 8 new tires on checked the fluids and will be attempting the drive back to Cleveland (364 miles). Wish us luck and I will post pictures from the trip.Attachment 264216
Congrats and welcome aboard. Check if your front airbags will hold air (55 psi), it will make your ride a lot more pleasant.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 06-11-2016, 08:06 AM   #3
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
It is just my imagination or have a bunch of 1987 325's suddenly been bought and sold these days. They are everywhere.:huh
Welcome to the forum, and other than air bags, you might want to make sure the gas card has lots of room.
BTW, only considered an adventure when something has gone totally south on you, leaving you stranded for days with no water, black tank full and since you haven't left yet..........which is actually pretty smart of you, as the Airstream Gods may leave you alone, as they think you want an adventure; reverse psychology, very smart indeed.
Goodluck
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 06-11-2016, 08:12 AM   #4
1989 34.5' Airstream 345
Ebro , Fla Panhandle
All the best on your shakedown cruise, and welcome aboard the forum.
You will find a sharing bunch here with grease under a few nails and big smiles on our faces.
These classics are wonderful machines to tour in.
Don't be surprised if the first few trips generate considerable to do lists.
Check in here for part #s, sources, tips etc.
Cheers Richard
tevake is offline   Reply With Quote
Old 06-11-2016, 11:33 AM   #5
comprose's Avatar
1999 31' Land Yacht
Kingston , Washington
Welcome to the world of Airsream motor homing. We just completed a 75 day almost 7,000 mile trip and thoroughly enjoyed the travel, and we're still speaking to each other. Not sure if Airstream trailer-types recognize MHs on the road, or even in the parks. But that's their problem.
Safe travels.
comprose is offline   Reply With Quote
Old 06-11-2016, 09:23 PM   #6
rmuller's Avatar
Madison , Ohio
Sorry no posts during the trip.. I have to admit I was a bit focused on the task at hand. Not only is this our first Airstream, it is our first RV.
We made the 406 mile trip in about 9 hours. The 345 ran like a champ, new tires made a big difference from the test drive. I have to say the mission was not to need a tow truck. Not only did we not need a tow truck but we didn't need the 500lbs of tools I had in the back of our VW, so that was an extra bonus!
Of course there were some issues that I will address during the summer.
1) It is HOT with no AC and 92 degrees outside. The 454 is like sitting on top of a volcano. I know I could have ran the generator but I didn't have time to service it before we left.
2) Lost the airbags about 50 miles from home. There is 80 lbs in the tank but it is not keeping the bags up as much as the beginning of the trip. Dash gauge was in the red. (Valve of some sort?)
3)Very weak brakes. Does the job I guess but not very comforting.
4) lots and lots of cleaning! And a refresh inside.
More to come I'm sure as I bring the coach systems online.
Name:	ImageUploadedByAirstream Forums1465698140.280359.jpg
ID:	264268Click image for larger version
Name:	ImageUploadedByAirstream Forums1465698152.729708.jpg
ID:	264269Click image for larger version
Name:	ImageUploadedByAirstream Forums1465698164.037913.jpg
ID:	264270Click image for larger version
Name:	ImageUploadedByAirstream Forums1465698174.276818.jpg
ID:	264271Click image for larger version
Name:	ImageUploadedByAirstream Forums1465698194.969505.jpg
ID:	264272Click image for larger version
Name:	ImageUploadedByAirstream Forums1465698208.090017.jpg
Old 06-11-2016, 09:31 PM   #7
Airstream Driver
1997 30' Excella
Images: 51
too cool (not a pun) you made it!!! Big congratulations! I have done it a couple of times, so have may others on this forum. It will bond you to the rig forever and once you start digging into it, you will say :I can't believe I made it home with this..........
I had to laugh out loud, when I saw you even left the for sale sign in the window
1996 Airstream B190
AIR #13
Old 06-12-2016, 04:28 AM   #8
1995 36' Classic 36
Ludington , Michigan
Congratulations! Glad the trip home was uneventful.
Kota is offline   Reply With Quote
Old 06-12-2016, 08:31 AM   #9
Dazed and Confused
Isuzusweet's Avatar
Whew; yes we have all had that feeling of just, lets just get home and take stock of what we have just done. Yes the learning curve is steep, but the crowd here will answer any question you have, including dumb ones.
Air bags sounds like the leveller valve got stuck, or some debris from inside the tank fouled it. I replaced the steel tank with aluminum ones and replaced the valve. Valve is around $90 and Brad can tell you the model number.
This will happen to you a lot in the first while you start using it. Things will work and then not........
As for brakes, well, I hate to tell you but what you see is what you get. My 310 weighing 3000 lbs less than yours has the same braking system, which is, normal braking is okay, but ask it to stop you any faster, no way; and this was after a new master cylinder ($90.00) and new fluid. If I were you I would get a new master cylinder if it hasn't been replaced at all and all the brake fluid replaced, especially if the coach sat for a few years. Roquefort found just brake jelly in his master cyclinder. Your tag axle brakes are probably not working well and also need servicing. Others can chip in on that.
Spray Nine and buckets of it will do a great job of cleaning up the interior.
Way to go mate, you made it.....now the fun begins.
Cheers
Tony
PS. Your very first thing to do would be to change the rubber fuel lines. These fuel lines were made pre Ethanol and Ethanol is very corrosive and will eventually cause them to crack and spill fuel all over the volcano, which is bad. We have lost a number of rigs over the years due to fuel/engine fires. It happens fast, by the time you realize what's happening, the little fire extinguisher supplied will just piss off the fire, but not put it out.
Old 06-12-2016, 08:34 PM   #10
rmuller's Avatar
Madison , Ohio
Thank you for the words of encouragement and tips, especially about the fuel lines, that is one I would not have thought about!
Got the generator working today, I am impressed with how quiet it is. It is nice to have A/C!
Question - has anyone tried to remove the coating on the interior aluminum skin and succeed? If so how much of a pain was it and how does it look?
Old 06-12-2016, 08:50 PM   #11
Airstream Driver
1997 30' Excella
Images: 51
I would go with SAE30R9, which is the more expensive fuel injection fuel line.
The clear coat is easy to remove. I like to use Citristrip from Home Depot. Protect adjacent areas and brush it on. You can either rinse it off with a water hose our wipe it off with a damp rag.
If you don't have excessive oxidation, it will look pretty good after you clean it up, if you do have oxidation, you have to polish to get it to look decent again.
BTW, if only your wood decal is peeling, but the gray upper and lower is still in good shape, you can remove the rest of the wooden decal with cheap white masking tape.
Replacing all of the pinstriping is rather expensive (~6.-/foot)
1996 Airstream B190
AIR #13
Old 06-12-2016, 09:04 PM   #12
Dazed and Confused
Isuzusweet's Avatar
First things first grasshopper.
Get the mechanical is good working order, stopping first, followed by steering, suspension and powertrain in that order.........trust me, that's a big one for this summer. Master cylinder, brake fluid, pads, Crank steering bells, lower ball joints, tie-rod ends, grease fittings, steering damper, transmission fluid, rear differential fluid, engine coolant, radiator condition with possible re-core, thermostat, FUEL LINES, drive belts, airbags (condition), air compressor, air tank, lights (marker, dock and headlamps), wipers, hydraulic levellers etc, etc.
Now interior to make it user friendly: clean first, check condition of sub floor, plumbing, pumps, toilet, black and grey tanks, dump fittings, hot water system, fridge, freezer (if applicable), 12 volt converter, lights, circuits and fuses, fans, stove, LP system and certification, furnaces, systems panel, curtains, dead bolt, etc, etc
Now you can go, stop and use it...........now it's time to make it pretty. I'm almost up to this stage,-almost- and I bought mine four years ago.
Peter will tell you how to strip your coach but be aware that keeping one of these in polished condition takes many, many, many hours of labour and will cut into your using it time.
Relax, take a breath first; it's not going anywhere soon, but you will if you try and do everything all at once.
Cheers
Tony
Old 06-12-2016, 09:39 PM   #13
rmuller's Avatar
Madison , Ohio
Thank you for the list of mechanical priorities, I appreciate it and will always prioritize safety first. I was asking more for conceptual purposes. I was referring to the interior aluminum skin. Has anyone taken that back down to aluminum and gotten rid of that sticky wall paper stuff?
Old 06-13-2016, 05:15 AM   #14
Peter, I believe the OP was asking about the interior skin.
345 Motorhome :: 2011 Airstream 345 cowboy7877 Airstream Registry Discussions 0 12-27-2011 04:38 PM
Off to LA....The Adventure begins JodynJeep On The Road... 29 11-20-2003 01:23 PM
New MH adventure k5cad Airstream Motorhome Forums 10 09-04-2003 06:33 PM
MACKINAW Adventure Chitown AirStreamers On The Road... 15 08-30-2003 05:31 AM
albert's excellent adventure john hd Our Community 13 08-06-2003 08:58 PM
