Old 08-16-2016, 06:29 PM   #57
rmuller's Avatar
Madison , Ohio
Does anyone know where I can get new center caps? Some of these have rusted out. The originals made by truck lite are out of production and I'm not sure what else will work since there are so many options available on the Internet.Click image for larger version
Name:	ImageUploadedByAirstream Forums1471390145.994183.jpg
ID:	269261Click image for larger version
Name:	ImageUploadedByAirstream Forums1471390158.361283.jpg
ID:	269262Click image for larger version
Name:	ImageUploadedByAirstream Forums1471390171.595367.jpg
ID:	269263Click image for larger version
Name:	ImageUploadedByAirstream Forums1471390192.067190.jpg
rmuller is offline   Reply With Quote
Old 08-17-2016, 01:41 AM   #58
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Try these guys. https://www.southwestwheel.com/c-12-...cessories.aspx I use #011911 and #011912. Sometimes you can find them for less on eBay.
Cheers, Dan
~ Margaret Thatcher ~
Old 08-17-2016, 09:28 PM   #59
rmuller's Avatar
Madison , Ohio
Thanks Smartstream, that takes care of the caps themselves, anyone know about the rings that hold them in place? I can imagine the 5 lug on the front will be harder to find.
Old 08-18-2016, 02:06 AM   #60
I'm using the 2 piece lug nuts #39946. https://www.southwestwheel.com/c-12-...aspx?pagenum=2
The caps fit flush on the face of the wheel and the lip of the cover fits under the edge of the washer of the lug nuts. It doesn't look like it will hold and you have to be careful making sure everything is centered while tightening the lugs but the cap is held very tight. I don't use rings on the rear and I turned aluminum rings on a lathe for the front. I made the inside diameter smaller so the cover sits on the plate and is held by the lug nuts.
Cheers, Dan
Old 08-18-2016, 05:40 AM   #61
1979 28' Airstream Excella 28
Albuquerque , New Mexico
[QUOTE=Isuzusweet;
PS. Your very first thing to do would be to change the rubber fuel lines. These fuel lines were made pre Ethanol and Ethanol is very corrosive and will eventually cause them to crack and spill fuel all over the volcano, which is bad. We have lost a number of rigs over the years due to fuel/engine fires. It happens fast, by the time you realize what's happening, the little fire extinguisher supplied will just piss off the fire, but not put it out.[/QUOTE]
is this also true for diesels?
kyote is offline   Reply With Quote
Old 08-19-2016, 05:54 AM   #62
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
I was refering to gasoline as there is no Ethanol in diesel and diesel requires an actual flame for it to ignite. Unless someone takes a blowtorch to your engine bay, you're good.
Diesel does have its own concerns, namely low sulphur content in modern diesel fuels which requires you add a fuel conditioner to get back the lubrication that has been taken out. The lubrication is required for seals in the fuel pump and injectors I believe. Buy a good diesel conditioner and you should be fine.
Cheers
Tony
Old 08-20-2016, 09:05 AM   #63
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
1991 35' Airstream 350
Images: 51
>>>>SAE 30R9 hose is also recommended for diesel and biodiesel fuel because its
fluoroelastomer tube resists deterioration caused by some diesel fuel additives. As
refineries produce cleaner fuels and lower allowable permeation rates during the “vehicle
at rest” condition, older hose specifications such as SAE 30R7 are becoming less reliable.<<<<<
http://www.gates.com/oreilly/tech_ti...elLineHose.pdf
1991 350LE
1996 Airstream B190
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 10-17-2016, 03:17 PM   #64
rmuller's Avatar
Madison , Ohio
I know it has been a while, but finally got a chance to work on the 345 today! I started refurbishing the slide out storage bins and outside compartments. I'm using spray on truck bed liner on the inside once all the rust is fixed. It's quite a project. I got my NOS Signal Stat patio light and 2 backup lights in the mail today along with the new Signal Stat license plate holder. Also painted the white cover for the new hot water tank to match the aluminum. Last but not least 2 new house batteries! Now if I could just have more productive days like this. Next project is install the new Bilstein shocks I ordered today.
Name:	ImageUploadedByAirstream Forums1476734818.075007.jpg
ID:	273683Click image for larger version
Name:	ImageUploadedByAirstream Forums1476735239.468522.jpg
ID:	273691Click image for larger version
Name:	ImageUploadedByAirstream Forums1476735250.067036.jpg
ID:	273692Click image for larger version
Name:	ImageUploadedByAirstream Forums1476735382.873301.jpg
ID:	273695Click image for larger version
Name:	ImageUploadedByAirstream Forums1476735402.010317.jpg
Old 10-17-2016, 05:11 PM   #65
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
It's nice when you find NOS parts, isn't it ? Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 11-04-2016, 09:41 PM   #66
rmuller's Avatar
Madison , Ohio
Was cleaning the 345 up and getting it ready for winter storage, just thought I had to share this cool picture.Click image for larger version
Name:	ImageUploadedByAirstream Forums1478313680.808455.jpg
345 Motorhome :: 2011 Airstream 345 cowboy7877 Airstream Registry Discussions 0 12-27-2011 04:38 PM
Off to LA....The Adventure begins JodynJeep On The Road... 29 11-20-2003 01:23 PM
New MH adventure k5cad Airstream Motorhome Forums 10 09-04-2003 06:33 PM
MACKINAW Adventure Chitown AirStreamers On The Road... 15 08-30-2003 05:31 AM
albert's excellent adventure john hd Our Community 13 08-06-2003 08:58 PM
